Question about Hampton Technologies Brinks Timer
I have a brinks 44-1011 timer would like to know how to turn completely off when not in use. Turn the clock off and everything
    New Friend:
Sorry to inform you, but it doesn't have that capability. The manufacturer probably figured the timer was a "disposable" once its battery dies. I have two of them, plus the instruction sheet, and the only thing you can do is have the outlet always "off".
Posted on Nov 05, 2013
  • Gene Haynes Nov 05, 2013
    Attach a photo so timer can be identified. Scan your manual into .pdf format and post link to your site where manual is available.
  • Hampton Tech... Master
  • 5,245 Answers
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/How-to-set-timers.html
Frequently the timer restarts at next set point.
Only a few timers have full off-on by-pass capability.
Gene
h
Posted on Oct 12, 2013
How do you reset timer for brinks 44-1011
stick end of paper clip or toothpick into reset home to reset timer to faCTORY defaults
This will clear memory settings that occur during manufacture and testing
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/brinks-timers-and-manuals.html
Gene
Sep 13, 2014 | Hardware & Accessories
How do I get my Brinks timer to come on at 7.30 pm and turn off at7..30 am
Do you know what model Brinks timer you have? This will help when searching for specifics on programming.
Sep 02, 2014 | Hardware & Accessories
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Help me work this thing please?
Brinks analog plug-in-outlet timer??
Copy following link for instructions how to set timer by experimenting with features:
Nov 02, 2012 | Hampton Technologies Brinks Timer
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
November 2010 I purchased a Brinks 42-1050 Outdoor timer for Christmas lights. Recently I tried to use if for a temporary pet light. Problem, the clock does not keep time. Can this clock be repaired. I...
This timer cannot be repaired.
Solution 1:
Timer has 1 year limited warranty from hampton products.
Warranty might apply.
Aug 2011: open following links for hampton:
http://www.hamptonproducts.com/customer-care.php
http://www.hamptonproducts.com/contact-us.php
Solution 2:
Buy another identical timer from Walmat etc.
Return defect timer in new package.
Aug 19, 2011 | Hampton Technologies Brinks Timer
The Brinks Model 42-1014 fails after a few weeks. The motor that turns the timer dial is not strong enought to trigger the on switch. I can move the dial by hand to turn it on and it does turn off but...
I agree.
I test timers.
Brinks timers are near lowest quality of all timer brands, yet all timer manufactures sell lower end products to meet price points. Brinks are probably made by one of the bigger brands.
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Test your outlet with cheap circuit analyzer from box store to make sure that polarity of outlet is not reversed. Notice that Brinks timers, like most plug-in timers, have polarized plug.
Polarized plug has wide and narrow blades so they plug into outlet correctly.
Wide blade is for Neutral, and narrow blade is for Hot.
If outlet has polarity reversed, this will adversely affect timer motors, and other appliances.
Jun 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
Hampton Technologies Brinks Timer Logo
455 people viewed this question
Top Hampton Technologies Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hampton Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
