Question about Crate Music
I have a Crate CR212 it started to hum/buzz today. It would not play out any sounds other than the noise. I unplugged everything and still it hummed. I unplugged the unit, check the fuse and replugged and the same thing. I tryed the channel selector from clean to distortion and it started some crackling and then it went dead. the fuse is intact and the house plug is good. I now got nothing .... no lights, no sounds, nothing.
    Problem Solver:
  • 17 Answers
Are all the tubes lighting up? they should glow like dim light bulbs. If not, replace them with the same model type (12ax7, or EL34 for example).
Often there are two fuses, one to protect the speaker and another to protect everything, it sounds like the latter fuse may be burned out. take it out and take it to radio Shack for exact replacement.
Posted on Oct 16, 2013
soundchasr
  • 8 Answers
SOURCE: NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Posted on Jul 25, 2009
  • 5603 Answers
SOURCE: Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Posted on Sep 30, 2009
Testimonial: "Thanks man. and thanks for the fast response"
RixsFixes
  • 2200 Answers
SOURCE: I have a crate PA 8 and it makes a crackling noise
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Posted on Oct 28, 2009
  • 5603 Answers
SOURCE: Constant hum/buzz only when the distortion is
Distortion is a very HIGH gain operation and any hum on the input will be amplified many times.
Check your guitar AND input cable for ANY hum at all at high gain settings on the amp WITHOUT the pedal in line to assure that the source is not before the pedal.
ADDITIONAL cause could be a poor power adapter for the pedal or even a bad filter cap in the pedal.
Posted on Nov 03, 2009
  • 5603 Answers
SOURCE: Have a Crate V50-112.Have had it for 1 year.
Check for bad tube... it HAPPENS that brand new ones fail... USUALLY if they last 50 hours, they will last for the expected life. The bad tube would likely NOT be the main power tubes, as the amp would still run on one cylinder...
Posted on Feb 02, 2010
My Cube 30 hums when I plug my guitar into it, buzzes really loud when on effect channel, clean when plugged into AUX
You have a bad ground somewhere. Try different cables and check the effect channel port if it is tight and secured.
Jun 02, 2016 | Music
Rocktron starts buzzing when I play it on keyboard
If it's disconnected from everything else, it may indeed be the power adapter. Try a different one, but also try it in a different location as well to see if it's picking up outside interference.
May 04, 2016 | Rocktron Banshee Guitar Talk Box Talkbox...
Only humming or buzzing , no music or sound
Try different cables. That would be the most simple and cheapest fix.
May 27, 2014 | Roland Kc-150 65-watt Keyboard Amplifier...
Hie, I Have got a crate tx 15 and, I have a sound problem, all time I have got a buzzzz... but there another thing too, the led for the battery recharge does'nt light and when I plug the electric...
Your symptoms would indicate the battery is defective. When a battery fails, its internal resistance goes up and they PROBABLY use this battery in place of having a separate filter capacitor so you will get hum or buzz as a result and no charging indication.
Sep 13, 2011 | Crate TX15 15W Guitar Amplifier
It constantly has a buzzing sound even when over drive is off and the noise is much louder than the output of the guitar
Start by unplugging anything attached to the amp to eliminate simple things such as a broken shield on an input cable.
If you still have the pronounced hum with nothing connected, then the amp's power supply may have a failed filter capacitor or diode bridge. Either of those would have to be sought by a tech with the right gear.
Jul 04, 2011 | Rogue SC40R 40W 2x8 Stereo Chorus Guitar...
The amp plays fine for about 15 to 20 minutes, then an extremely loud, over powering hum/buzz takes over, and then the amp has to be turned off, but the problem persists. I've tried several guitars,...
You say the "tubes are fine" I take it that you have either replaced them with new or used a very sophisticated tester on them. A heater-cathode short might cause the symptom. There are a bunch of tests I would want you to run alnd get back to me with the results.
Heat up the amp but DO NOT play anything into it for the usual failure time or more and they start to play i... did hum occur WITHOUT playing? With all volume controls down does the hum occur?
The right tools is an oscilloscpe to fing out if the filter caps are good. These are C31, C33, C35, C36.
With hum present in failed stater, plug in a grounded plug into the power amp in jack... if hum is stiil there, check the +/- 16 volts regulating Zener for ripple. get schematic here:
http://elektrotanya.com/fender_hot-rod-deluxe_sch.pdf/download.html
Jan 29, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Just got my fender 63 reverb reissue unit...and when i switch it on all i get is a loud buzzing hum type sound .
If you unplug the guitar cable and STILL get the hum, the unit has a defect... return under warranty.
If the hum goes away when you unplug the cable, replace the cable and see if new cable fixes the problem. If it does, the cable has a bad shield.
If the cable didn't cure it, then the guitar has a defect. Remember that some guitar pickups are sensitive to the magnetic fields from the amps... only cure is to either use humbucker types or be a distance away from the amp.
Jun 29, 2010 | Fender '63 Reverb
I bought a Crate CR212 new in 84 It came with celestians they are
I can't be sure for the result at your area, but I have to tell you that whenever I rebuild speakers at technicians in Greece (that's my country), the results were not very good. They always worked but after some working period started to make strange noices. Especially if you are a mucisian and the amplifier is yourself, replace them.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 10, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
Mar 26, 2010 | Fender '72 Tele Deluxe Electric Guitar
Jul 12, 2009 | Music
Music Logo
87 people viewed this question
Top Crate Music Experts
rjivaro
Michial Gueffroy
Ben Armstrong
Are you a Crate Music Expert? Answer questions, earn points and help others
