Question about Imperial IFS40 Deep Fryer
What does the gas adjustment screw look like on a lg400 gas fryer
  • 9,639 Answers
There is no gas adjustment screw. There is an air ratio adjustment on each burner. Loosen the screw that holds the flame adjuster and turn the stamped metal adjuster until there is no orange portion of the flame visible. Tighten the screw and you're done.
Posted on Jan 01, 2016
Gas valve knob continues to turn, won't lite pilot, although knob pushes in fine
Replace the knob. There is a groove that the knob uses to put the valve core in the right position.
Feb 19, 2016 | Vulcan LG400 Deep Fryer
If wires are crossed will burner work
It depends on which wires are crossed. Switching the wires on a two wire high limit, thermostat, or thermopile will not matter. The wiring on the gas valve must be correct for the fryer to work properly and safely.
May 29, 2014 | Vulcan Kitchen Appliances - Others
I have a Vulcan lg400 propane fryer I have used 4 times at outdoor catering events over the last year yesterday while using it it began what I would call backdrafting. could low propane level in bottle...
It sure did. Never use a gas fryer in low gas pressure for a long time for soot will build up inside the fire tubes.
Check and clean fire tubes, make sure that the flue is not restricted and there should be no air entering the flue.
Regards.
Nov 03, 2013 | Vulcan LG400 Deep Fryer
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
Nov 03, 2013 | Vulcan 1VK85DF Hi-efficiency Gas Fryer...
Pilot wont lit
The first thing to do is make sure all the air has been purged from the gas line.
Oct 12, 2013 | Vulcan GR45 Deep Fryer
Pilot light wont stay lit
Can I first ask you to be more specific to what the pilot light is in. A Furnace. Stove or hot water heater.
Please furnish at least the name and model of the device so that I can better answer your question.
Oct 12, 2013 | Vulcan LG400 Deep Fryer
Need to adjust pilot light could you explain how? Thanks
Hi there.
Pilot light on Millivolt Gas Valve can be adjusted by removing the screw (with pilot adj mark) just below the gas valve knob and tightening (to increase pilot flame) or loosening (to decrease pilot flame) the screw inside. However, make sure that the gas pressure is sufficient and the pilot assembly is clean before doing this.
Regards.
Jul 21, 2011 | Pitco Frialator 35CS Deep Fryer
Fryer pilot lit but main burner does not come on
IT IS A GAS PRESSURE PROBLEM CHECK TO SEE IF THERE IS A GAS REGULATOR IN LINE WITH THE GAS PIPE TO THE FRYER IF SO ADJUST REGULATOR TAKE TOP ALUMINUM SCREW OF YOU WILL SEE WHITE PLASTIC SCREW TURN WHITE SCREWW TO THE RIGHT ALL THE WAY IF SAME PROBLEM OR NO REGULATOR RESTICTION IN GAS LINE
Nov 10, 2008 | Imperial IFS40 Deep Fryer
Pilot light
On the gas valve there is an adjustment for the pilot it usually is a machine head type screw if you remove it there is a limit adjustment for the pilot under that. It will not be the flat cap type screw and it will not be a black plastic inner screw to adjust, it should be a metal brass screw you adjust. Not trying to throw to much info at you just making sure you get the right screw to adjust the pilot. The flat metal cap cover screw with the black plastic screw underneath is the pressure regulation adjustment, so it is critical not to touch it.
Hope this helps You
please rate me
Jul 23, 2008 | Imperial IFS40 Deep Fryer
Adjusting main burner flame
Goto the gas valve,you will see 2 slotted silver caps 1 small 1 big.unscrew the big cap then youll see a white plastic screw.turn this screw counterclockwise to increase the gas pressure,clockwise decreases pressure.nat. gas pressure should be 3.5 inches of water colum
Feb 11, 2008 | Pitco Frialator 35C Deep Fryer
Imperial IFS40 Deep Fryer Logo
169 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
paulcarew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
