Question about Yard Machines Garden
Mower engine not firing but brand new spark plug and clean fuel
  • 3 Answers
Did you varify spark? How long was it sitting? if you have spark, may need to clean out carburetor float bowl. inspect it for sediment that could be clogging jets. clean carb. with todays gas containing 10% ethenol it really eats up the inside of fuel lines so may want to replace the fuel line if your mower is getting up there in age. If you have spark try spraying some WD40 into the spark plug hole , re insert plug and try to start. If it starts for a few seconds then you know its carb. good luck
Posted on Oct 12, 2013
4 Suggested Answers
SOURCE: Craftsman 56''mower draining new battery rapidly-not recharging...
JUNK IT ITS A PIECE OF ****
Posted on Jun 08, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Posted on Apr 25, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
Lawnboy mower model 10743 will not start
When choke not on all the way coil willnot activate and throw spark ps carby should be cleaned out properly because fuel will off evaporated leaving oil guming up needle/seat
Jul 03, 2016 | Garden
Riding mower with 42a707 Briggs engine won't fire. Changed plugs air filter fuel filter oil. carb is clean and getting gas.using new gas.
Ken are you getting any spark at the plugs ?
If not remove air housing to expose fly wheel and spark coil there is a ground wire going to coil, unplug it to see if you get spark now if not you need a new spark coil.
Jun 22, 2016 | Garden
Gets fuel & fire. Why won't it run?
danny, i had a john deere come in that had great fire and good fuel. i worked on it two days. for some reason i changed the new spark plug that was in it for an old one i had. it started and ran great. just because it has spark does not mean that the plug is good. try to change the spark plug. hope this helps you.
Jan 22, 2016 | Garden
Why will Ariens lawn mower starter engine not turn over?
These machines have carb and coil issues. Check for fire. Nice when new, but once a little age creeps in, the engines just aren't that sturdy. Sorry, but as a small equipment mechanic, I don't recommend Lawn Boy. Next time, buy another brand.
May 30, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Suffolk Punch 35s not starting
carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Apr 12, 2014 | Garden
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Honda push mower wont run right
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Mar 24, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
