Question about Ovens
How do I remove the Thermador SC272TS built-in wall oven to install the Display Kit?
  • Carl Louck
    Carl Louck Oct 13, 2013
    It appears that after removing the oven doors that a "frame" is screwed to the cabinet with four screws. Does removing these srews release the oven pair so that they can be "slid" from the cabinet to provide access to the control panel?
SOURCE: Control panel disassembly
Shut the breaker off to the oven first. Frame around mircowave is a snapped on front. Removing allows access to two screws under control panal. Must actually pull entire unit out about 9 inches to access top of control area to remove access panel. Once front control panel is removed and top is opened, easy access to what you need to get to. Carefully write down color coding of wires before removing any of them. Remove old power supply board and display and reconnect. Reverse process. A bit of work but if you watch the disassembly process carefully, pretty easy.
Posted on Jul 12, 2008
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
SOURCE: thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Posted on Sep 19, 2009
SOURCE: I have a Thermador SC301 wall oven and the display
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Posted on May 03, 2010
vetteman3002
  • 2299 Answers
SOURCE: Thermador SC272TS (1998) Double Oven. Bottom oven
Usually it is the thermostat that causes both the boil or bake not to work. If it was one or the other it would be a different problem. But the thermostat is telling the controller that the temp is already to high. And will not let the elements heat up.
Posted on Oct 25, 2010
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
The control panel display is so light that it can not be read. I have a double built in oven SCD302. What can be done?
Hello, welcome to FixYa.
There are two common scenarios with these Thermador wall ovens fitting what you've described. The harness to the display from the control board is loose (not likely) or the display itself is failing (most likely).
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available, but a "kit" is.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
You may find other suggestions or "band aid" remedies on-line, but in my experience this is the sure way to go. Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 14, 2011 | Thermador SC302T Electric Double Oven
I have thermador double electric wall ovens and I have slowly over time lost the abilitty to read the information in the window display. I took off the face plate in the hopes that it was a simple bulb or...
You need a new display kit. The display kit has a new clock relay board and the white harness to the clock. The repair is straight forward.
Apr 22, 2011 | Ovens
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
Thermador SCD302 NO Illumination on Display window
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
Sep 27, 2010 | Thermador SC302T Electric Double Oven
Hi, I have a thermador double oven model SC272TS. The lights on the display panel are very faint. Any idea which parts need to be replaced?
I found this parts list that may be helpful...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232201&diagram_id=194155#d194155
Sep 02, 2010 | Thermador SC272T Electric Double Oven
I have a Thermador SC301 wall oven and the display has faded out. Thermador says I need to replace the whole control unit ($500 for the part!) Any cheaper fix?
Feb 08, 2010 | Thermador Ovens
Thermador oven display is dimming
theblog
Nov 29, 2007 | Ovens
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Clock display too dim
You are going to need a display kit to fix this. It comes with a new display and relay board. The kit is about $200 and is somewhat difficult to install. This repair altogether usually runs about $400 to fix if you dont have someone handy that can do it for you. It involves removing and replacing at least 20 wires from the relay boards, as well as either pulling the oven from the wall or working in a tight space to change the board. You may be able to find just the display board somewhere, and that is very easy to install, but I've only ever gotten the part as a kit. Hate to be the bearer of bad news. Good Luck!
Aug 16, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
