Question about HP DeskJet 3740 InkJet Printer
Windows 7 driver install - HP DeskJet 3740 InkJet Printer
My LG X200 works with Windows 7. Can I install XP on this model. And if I install XP, the drivers available for windows 7 will work on XP?
The drivers for Wndows 7 most likely will not work on Windows XP.
If this laptop came installed with Windows 7 it may not have Windows XP drivers.
Before you install Windows XP check the LG WEB site for Windows XP drivers for your model laptop. If there isn't any XP drivers then I suggest you stick with Windows 7.
May 20, 2011 | Computers & Internet
Cannot install drivers for Canon MF5550 on Windows 7 64 bit O.S.
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
http://www.makeuseof.com/tag/3-resources-windows-7-printer-drivers-printer-working/
Jan 07, 2011 | Canon imageCLASS MF5550 All-In-One Laser...
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
Can i install windows 7 on hp 530 core duo
Yes, you can install Windows 7 on Hp 530 series Notebook.But HP doesn't release any drivers for your notebook for Windows 7.
You install Windows 7 and try to install drivers which are meant for Windows Vista.
If you are trying to install Windows 7 Ultimate or bussiness edition then try to install Windows vista bussiness driver (32-bit).
you can download the driver from the link below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swLang=8&taskId=135&swEnvOID=2096
If you are trying to install Windows 7 Home edition then try to install Windows vista Home driver (32-bit).
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swLang=8&taskId=135&swEnvOID=2094
Remember to check whether the Windows 7 is 32 bit not 64 bit version.
Most probably all the drivers will work fine as 90% of the drivers which are meant for windows Vista works fine with windows 7.
Even if you have miss out some drivers or not able to install,you can download "Driver Genius Pro" using the link below
http://hotfile.com/dl/9305335/2e7a110/29Genius.rar.html
It's full version and you will be able to update or download the lastest drivers from the manufacturer sites directly using that software.
Hope you enjoy Windows 7.
Jan 26, 2010 | HP Computers & Internet
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
I installed windows 7 and now my function keys don't work
You need to install the drivers, windows does not recognize these additional buttons until the proper drivers are loaded. Depending on manufacturer windows 7 drivers may or may not be available. Microsoft did something smart with windows 7 by allowing you to use windows vista drivers in windows 7. So if there are no win 7 drivers just download and install the vista drivers. Good luck!
Dec 04, 2009 | Sony VAIO VGN-A690 Notebook
Video drivers not installing on windows 7
You use windows 7 but you must be need all hard ware support driver,windows 7 need 64 bit support driver.You upgrade your display driver from www.mercury .support.com
Nov 26, 2009 | Mercury P4VM800M7 Motherboard
Unable to install driver of HP deskjet 3740 on window 7
HP doesn't have the drivers available for windows 7 cause its only in Beta and they won't have it until windows 7 becomes official and available in stores. The only chance would be if you go into the control panel and then add printers. See if in there it has your make and model of your printer. If it doesn't then try a printer that is similar and it might install it. If you still can't get it to install then you'll have to wait for HP to come out with a driver for windows 7.
Jun 08, 2009 | HP DeskJet 3740 InkJet Printer
HP DeskJet 3740 InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
