Question about D-Link DIR-600L Wireless N150 Cloud Router
I have a PPPoe internet connection with no modem and when the router is installed between the computer and the wall jack I can't connect to the internet
    Sergeant:
  • 396 Answers
CLICK HERE for the user guide for this device. Page 17 is where you will find the internet type settings. This device requires m DSL modem to work. It does not work to plug it into a telephone line into it, as that is too small of a connector, and could damage the router.
Posted on Oct 12, 2013
osborne382
  • 306 Answers
SOURCE: no internet light on modem afer router is used
go to http://support.dlink.com/chooseCountry.asp
for proper set up of the router...most likely it has conflicting IP Address's. If they wont help you can contact your ISP for support or get a differ router.
Posted on Nov 10, 2007
SOURCE: No internet connection through router D-Link DI-524
Lost internet connection morning of 1/15/08 through router and directly through laptop 1. But, can get internet connection directly for laptop 2 and laptop 3! Cannot get a valid IP address anymore when laptop 1 is directly connected. Also, I discovered ping works for any lettered website even when the router is not connected to the wall, but correctly times out for a numbered website (eg 216.31.156.10). Completely stumped. Please help!
Posted on Jan 15, 2008
mlake33
  • 427 Answers
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Posted on Apr 12, 2008
SOURCE: No internet connection.
Login to your router (default address is "http://192.168.0.1/" (default username = "admin" and default password = "" (blank))). Then click on "Manual Configure", scroll down and click on "Clone MAC Address".
I hope this works for you too.
Posted on Jun 04, 2008
  • 226 Answers
SOURCE: Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Posted on Jul 20, 2009
My d link router will not connect to the internet from my phone jack. I where I receive my phone and internet connections. What steps do I take to install to receive the highh speed connections?
The phone jack must be connected to a modem, which is then connected to the router via an ethernet cable. To connect:
1. Connect the phone cord from the jack in the wall to the jack in your modem of choice. Turn on the modem. 2. Connect a CAT-5 ethernet cable from the correct jack in the modem to the correct jack in the router. 3. If using a wired connection, connect an ethernet cable from the router to your computer. Otherwise, simply activate the wireless card of your computer and select from the available wireless networks.
Mar 11, 2011 | D-Link Office Equipment & Supplies
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
Step 4
Step 5
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Can connect to router, but router wont connect to internet
The router needs to be configured manually. Follow the steps below.
Step 1
Step 2
Step 3
Step 4
Step 5
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing).
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Oct 06, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I am trying to install a Netgear WGR614v9 router. Disk will not install it, so tried a manual install. Shut down all firewalls, used no passwords or security settings. It keeps throwing me back to the...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing). Or password is admin also.
Step 3
Step 4
Step 5
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing). Or password is admin as well.
Oct 06, 2009 | NetGear WGR614 Wireless Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Using a ppoe connection to a DI-524 is it necessary to put a modem in line?
DSL connection:
Computer -> Router(Dlink) -> DSL Modem -> Telephone wall jack/outlet
OR
Computer -> DSL Modem -> Telephone wall jack/outlet
PPPOE = using a username/password combination to authenticate the connection to the ISP.
Nov 04, 2008 | Computers & Internet
Setting up a wireless router
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Nov 30, 2007 | D-Link DI-624M Router (DI624MRE)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
D-Link DIR-600L Wireless N150 Cloud Router Logo
60 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
