Question about McCulloch Garden
I have a McCulloch MS1839AVCC and need a replacement bar and chain. the original bar is not available. Any suggestions?
    Sergeant:
  • 340 Answers
Hi Dave there is a place called central spares that do a universal bar depending on the size. Also the chains are done by ALM and then you just need to know how many links the old one was.
Posted on Oct 12, 2013
  • 211 Answers
SOURCE: McCulloch mini mac 35. Badly worn chain
Hi
You need a chain with these carracteristics:3/8 ,PM,1.3 and the chain bar has 14" length.Hope this helps.
regards savumihai71
Posted on Dec 09, 2008
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
SOURCE: need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Posted on Mar 16, 2009
  • 226 Answers
SOURCE: Can't get the chain oiler to work. Using standard bar oil.
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Posted on Apr 26, 2009
  • 4088 Answers
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Posted on Jul 04, 2009
Oil level in motor of 3200 mcculloch chainsaw
This a 2 cycle engine where fuel oil is mixed with the gasoline. The mix is 40:1. If you attempt to run straight gas in this engine you will destroy it as would using regular oil.
The oil tank on this saw is for the lubing the chain and needs topping off every so often as you use the saw so that the chain stays oiled.
With the original McCulloch manufacture being out business parts are very hard to come if you can even find them.
Dec 03, 2014 | McCulloch 3200 Bar & Clutch Cover
Silver Streak chainsaw bar and chain
Replacement Silver Streak Bars For McCulloch Chainsaws Find your Chain Saw model, then click on the link to get the ChainSaw Bar and Chainsaw Chain for each model!
Special! Get 30% off when you buy bar and chain together!
http://www.jackssmallengines.com/chainsaw_bar_silver.cfm?manu_name=McCulloch
Jul 19, 2012 | McCulloch Garden
Could you tell me what the oil mixture is for the saw
http://www.mccullochpower.com/node7887.aspx
Mcculloch web site says 40:1 ratio
There are 128 ounces in a gallon
divide 128 by 40 = 3.2
So you need 3.2 ounces of 2-cycle oil per gallon of gasoline
Don't forget, you also need bar-oil in reservoir that lubricates chain
Mcculloch has manuals for you to download
I suggest you get a copy of your manual while available, and read the manual
Most companies don't have old manuals, so a few years from now, your manual may not be found
Oct 09, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where can I locate a chain & bar for a McCulloch Mac 110 Chain saw? Will a 12" bar and chain work?
it should if the chain is the same as to old one, just a long as it fits in the clutch.
Mar 15, 2010 | McCulloch Garden
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
I have a MAC 3516 and need a replacement bar and chain. The original Chain and bar are not available. the saw runs good but need the primer bulb and chain bar and chain. Any ideas would be great.
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | McCulloch Garden
What weight oil to use for a McCulloch electric chain saw with self oiler
Bar and Chain oil, available at Home Centers and Hardware stores. It is 30 weight non-detergent with additives to keep it on the bar and chain. It's less expensive than motor oil by the quart. HTH
Lou
Nov 12, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Need to replace chain on 450s mcculloch chain saw
You might want to purchase a combination set with a new bar and chain, if so, Oregon #108764 is the 16" length set.
If you only want either a chain or bar, then the following are the correct ones for your chainsaw:
Chain 16" @ 3/8" pitch = #91VX054G (low profile, semi-chisel)
Bar 16" = Oregon #160SDEA318 (w adjustable chain tensioner)
Bar 16" = Oregon #160SDET318 (no adjustable bar slot for use on chainsaw originally equipped with the Intenz bar only)
Hope you find this very helpful and best regards!
Aug 16, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Need to replace gas line inside mcculloch chain
Jun 30, 2009 | Garden
McCulloch Pro Mac 610 replacement chain
The McCulloch ProMac 600 series (610/650) doesn't recommend a saw chain replacement part because you can get differently-sized bars for it. This one came with a 20" bar.
According to an Amazon.com search tonight, the Oregon company makes a replacement part stock number D70. I have got an Oregon H78 replacement chain at my hardware store and it's a hair too small. Not all 20" saw chains are created equal!!
Dec 07, 2008 | Oregon Scientific Oregon S54 Replacement...
Garden Logo
32 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
