Question about Haier HC48C1VAR Central Air Conditioner
Ourtdoor is running for less than 1 hour and stop E6 will appear
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
E6 code come for room sensor failure , check sensor in outdoor for any damage or cut
Posted on Oct 15, 2013
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Manual for a tc29578be1-a
http://www.wonder.com.tw/download/pdf/TC29578BE1-A%E8%AA%AA%E6%98%8E%E6%9B%B8.pdf
This is the only web site I found and it appears to be in an Asian dialect. Try running it through google translate. Good luck.
Jul 13, 2014 | Thomson Lands Phones
Hi all...I was stuck in a horrible traffic jam 4 2 hours...in which 1 1/2 hrs were less than 5 mph. My truck is a 2003 Ford Escape. My radio went out then the lights started 2 dim and a brake light came...
I suppose its possible the alternator stopped charging the battery enough at the low engine speed but then worked on the way home.
The alternator will charge 12 - 13 volts at idle, but you could have enough accessories and the cooling fan running to use more voltage or amps than it is producing. Stopping at a traffic light for a couple of minutes does not hurt anything since the battery is usually fully charged. But idling for an hour or more with everything on could run the battery down.
You might want to have the computer checked for codes even tho the check engine light may not have been on. Also have the alternator and battery tested again to see if something happened while in heavy traffic.
Feb 14, 2013 | 2003 Ford Escape
Hb pioneer pro treadmill gone to full incline with E6 fault code, how do i fix it
Please RUN the software calibration instruction is UNder the hood motor cover. and follow steps. this is for diagnose, troubleshooting and fix it.
then lubricate the gear and shaft elevation motor.
God bless you
Aug 05, 2012 | Exercise & Fitness
Mijn printer canon mp260 geeft error E6 wat betekend
To Fix this Error Code E6 on Printer Canon MP198, You only need Press Color Copy Button about 1 minute until the display in Progress.
It happened If you have CIS, the cartridge chip only known original ink from the manufactured. After original ink run out the E6 Error message will appear.
hope this helps
May 18, 2011 | Computers & Internet
How do I set my woods photoelectric timer? It has one button that when the number 0 appears and when pushed again a double line appears. For every time I push the button numbers 1-9 appear. Do you have...
I think this switch is set to go on at dark, then you can set how many hours after it goes on you want it go off. If you want the device to go on at dark and run for 2 hours, you stop at 2.
Gary
Dec 19, 2010 | Woods Outdoor Photoelectric 24 Hour...
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
The furnace won't stop at the programmed temperature set ponts
this is called a swing tempature it is desined to improve the eficincey of the frnace because it take less energy to run an hour in a three hours then 3 bursts of 25 min in a three hour period
HOWEVER if you do not like this you can usualy set the swing temp
Jan 16, 2009 | Hunter Fan Company 5/1/1 Programmable...
GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
May 12, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Haier HC48C1VAR Central Air Conditioner Logo
177 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
