Question about Protech Rheem/12895 - Thermistor Kit - Rheem/Ruud/ A complete
FAN WANT CUT OFF WHEN THE AC DOES AND THE FAN S ON PROTECH AC THERMOSTAT HAV CUT IT WAY UP AND ALSO TOOK THE BATTERIS OUT I HEAR THE AC CUT OFF HOWEVER THE AIR STILL COMES OUT NOT COLD THRO
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
This is snubber error. I hope there is no snuuber in PCB. It is not a issue. Just restart the ac agian.
Posted on Oct 16, 2013
520 protech thermostat
What wires land where on
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 28, 2018 | Heating & Cooling
Ruud thermostat protech 500
Replace the thermostat.
Dec 05, 2013 | Heating & Cooling
Dihatsu Charde 92 new water pump no thermostat new radiator still over heats? Help
replace your fan radiator sensor; your fan should come on without the ac anytime the engine heat becomed excessive
Feb 19, 2013 | 1992 Daihatsu Charade
Filled Coolant reservior and radiator Drove trailblazer at highway speed no cooling problem. When slowed down in traffic temperature increased to about 220 and higher, could hear coolant bubbling in...
If there is bubbles occurring even inside the top part of the radiator (where you have the coolant put in), you may have a leak on your head gasket. You may be loosing coolant through the engine.
Sep 15, 2011 | 2004 Chevrolet TrailBlazer
AC WORKS FINE HEAT COMES ON BUT WHEN TEMP IS REACHED FAN NEVER GOES OFF AND TROUBLE WITH HEAT COMING BACK ON
When temp reached to thermostat level heatewr only will cut off not the blower. And secondly all thermostat at heat stage will cut off at the end of +2 degree and cut in starting of -2 degree.
E.g; If you keep 30 degree heat it will cut off at 32 and cut in 28 degree.
Dec 07, 2010 | Crosley CAE12ESR Air Conditioner
Ac fan stoped working all of sudden the other day I hav checked the fuses and the relays. and when I turn the fan on high I hear a click what do you think the problem is?
Look to see if the ac compressor is turning,look at the center of the pulley on the compressor,if it is turning,it could be a stopped up orifice tube,if it is not turning,check the freon,make sure you have not got a leak.
Jul 05, 2010 | 2004 Mercury Grand Marquis
Heat/AC unit will not kick on.
sounds like spark ignition coil bad the little fan combustion fan will run even after a fail ign attempt.
turn off power/restore power the unit will try to fire the part is easilly avail and easy to replace
Jan 18, 2010 | Ruud UBHC Air Conditioner
I have a 2001 mazda mpv and is overheating bothfan are not woking all relays checked out ok i also replace the cooling sending unit and still not woking someone said to check the thermal fan switch but i...
Turn on your A/C, is at least (1) fan on? NO? You need to replace at least (1) fan, that is the AC fan. YES? Then at least you now you AC fan works.
Make sure you have enough coolant in your car. DON NOT OPEN RADIATOR WHEN HOT. The Coolant Switch will noever cut on if there is no coolant there to trigger it. You can find it where the thermostat housing is.
Next, get a 12V testlight and test the wiring going to the fans. BE CAREFUL NOT TO GET CUT MY A FANIF IT TURNS ON! If you have electricity, but the fan does not cut on you fan needs repacing.
Sep 10, 2009 | 2001 Mazda MPV
I have a simple comfort 2000 thermostat and the fan will not cut off unless I cut the breaker off. The thermostat cuts the ac unit off and on but the fan will not go off. What could be the problem. I only...
Sounds like the Fan/Auto switch is not working or is out of the circuit. Do you have a Volt/Ohm meter to check the switch? Set the meter on Ohms on the lowest range, turn off the breaker, disconnect the leads from the switch, and put the probes on the connections to the switch. The reading will be near zero when you touch the leads to connections that are turned on by the switch. You can buy cheap meters at Harbor Freight ($5) or other discount places. If the switch is working, it has been bypassed somehow, or the wires are connected wrong. Did you recently install the thermostat?
Aug 21, 2009 | Heating & Cooling
Ruud gas pack has stopped heating.
Could be a faulty thermostat, (referring to the furnace\heater. As far as the A.C., you must have a dual thermostat with a switch for A.C. and Heating. Is the thermostat digital or mercury bulb? As for the A.C. it sounds like it is going off on high discharge pressure. Is the cooling fan running that cools the condenser? It must be spinning freely or it may be starting and because it is partially seized, it will cut off with a high current draw. Anyways, the condenser must be clear of any debris, no shrubs around it. The compressor could be bad and trying to start but goes off on overload because it isn't starting. It's start capacitor could be bad and not giving it that extra boost on start up which is what a start capacitor does. Good luck.
May 31, 2009 | Ruud UAMB Air Conditioner
Protech Rheem/12895 - Thermistor Kit - Rheem/Ruud/ A complete Logo
82 people viewed this question
Top Protech Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Protech Heating and Cooling Expert? Answer questions, earn points and help others
