Question about Cell Phones
Globe pin number - Cell Phones
Don't have asolution
Posted on Oct 12, 2013
What causes one headlight to be brighter than the other
It can be due to a number of causes
- one globe blackened and failing
- one reflector tarnished more than the other
- one outer lens more yellowed
- headlight units badly aligned
- one wiring connector loose or corroded
You just have to be methodical about it. Swap the globes around, check the headlight aim, remove and replace the connectors a few times each to wipe the pins inside. If you have a meter, check the voltage at each side. Look for yellowing, tarnishing or water inside the headlight unit.
Jul 17, 2014 | Toyota Camry Cars & Trucks
Low beam headlights blowing only 1 at a time both sides 5 x
check for loose globes and loose connections at the pins of the globes as arcing causes light failures.
Jan 02, 2014 | Cars & Trucks
On a 1995 chevy g20 van aren't all four headlights suppose to be active on high beams?
mostly no. there are two beams circuits A high beam (2 globes one each side) and a low beam circuit ( 2 bulbs one on each side) The globes should be A4 bulbs which have 3 pins on the back One pin is high beam and the other pin is for low beam while the middle pin is the earth pin for both sides.
Dec 25, 2013 | Cars & Trucks
+639170000240, +639170000247, +639170000248 smart message centers, which areas in the Philippines
Hi!! I'm sorry, but locations cannot be traced using those numbers alone unless you have Phone tracker featured on your phone. Numbers starting 0917 means they are GLOBE handy phone carriers. If you know someone living in the Philippines, you might want to instruct them to buy Globe Sim card then go to Globe Prepaid- Specials-Tracker-Person Tracker- then enter those number listed above to track where in the Philippines these mobile Globe numbers are.
Hope this helps. Thank you for using Fixya! May you have a good day.
Mar 30, 2011 | Nokia Cell Phones
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Jun 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How to open Globe gprs to Nokia 6303
GPRS SETTINGS
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
11. Change Homepage
Title: MyGlobe
12. Save Changes
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
4. Save Account
Connect Using: MyGlobe Stream
Jun 26, 2010 | Nokia 6303 Cell Phone
A wrong pin code was entered trice and blocked the pin code. how can i get the puk code from globe telecom. pls help, i had that sim for 5 years
If you no longer have the PUK code that came form the pack when you purchased your sim, then the only thing you can do it to go to the nearest Globe Telecom Office near you.
I was able to experience your problem with both Globe and Smart. Globe is more willing to assist, tho.
Goodluck and hope you can rate my solution. :)
Aug 01, 2009 | Nokia N95 Cellular Phone
HOW CAN I UNLOCK GLOBE SIM CARD PUK CODE?
Call your service provider customer care toolfree hotline . If they say this line " Not on prepaid but can check on postpaid." your somewhere in SEAsia.
Regards
Apr 06, 2009 | Nokia 6300 Cellular Phone
soso!
1. magbihis ka.
2. maglakad patungo sa kahit anung bisnes center ng globo (globe)
3. hwag kalimutang dalhin ang sumusunod, sim card, pamasahe at ang iyong extrang pera pang meryenda.
4. pumasok sa globe bisnes center iabot and sim, at isalaysay ang nangyaring trahedya.
5. papalitan ng kumpanya ng blangkong sim card at gagamitin muli ang iyong numero, sa ganitong paraan hindi mo na kailangan mag apdeyt ng mga kontaks mo na bago na ang iyong numero.
6. ang serbsiyong ito ay libre, inuulit ko ito ay libre. ibig sabihin walang bayad o kahit anung kapalit, kahit manok o banga.
7. umuwi.
Jan 09, 2008 | Samsung SGH-D500 Cellular Phone
No power to projector
Generally when the globe goes end of life and needs replacing the unit will fail to power up. Try another globe if you have one spare.
Sep 10, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
