Question about Microwave Ovens
Sharp sound bar buzzing - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Test this steps and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Posted on Oct 12, 2013
Sharp microwave kb-6002ls making buzzing noise
Someone would have to open the unit to "hear" where it is coming from, possible fan issue or even the power unit inside.
Dec 03, 2012 | Sharp KB-6002LS 1000 Watts Convection /...
Microwave made severe buzzing sound and quit working
SOUNDS LIKE THE MAGNETRON. IF SO REPLACE.
Mar 10, 2010 | Sharp Microwave Ovens
Sharp R-150 microwave made a buzz sound and shut off, no power to microwave
When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. Also usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Feb 07, 2010 | Sharp Microwave Ovens
I bought a Sharp Carousel 1100 watt microwave about 8 months ago but now it makes a louder noise when it's on and it doesn't heat. Can I easily fix this myself or is this now trash?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron.
Since it's less than a year old, it's fully under warranty and Sharp will fix it free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online to get it fixed.
Jan 30, 2010 | Sharp Microwave Ovens
Loud buzzing sound. Heats ok
may be the hi voltage . or a loose metal panel but its not normal and wiil probably lead to a failure like no heat . . most common would be a fan motor / high voltage / transformer / hope this helps **** ..
Jan 09, 2010 | Sharp R-403HW Microwave Oven
It sounds like the microwave is 'sparking' (buzz, buzz, buzz) inside. When I turn it off and open door, small amount of smoke is inside. It is a Sharp model R-4W36 or R4W38 that I bought in 1996. Is the...
It may be a failing magnetron, but the first thing I would suspect is arcing due to grease or food particles.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can order Sharp parts at Encompass here or call them at 866-779-5835.
Jan 08, 2010 | Sharp Microwave Ovens
Sharp R-7A82, buzzing/no heat
buzzinsg / humming / loud or louder than normal .is probably the mag / it has failed and the trans is making that noise . if older than 5 yrs I would replace ans the mag is 100.00 + and w / labor you have paid for a new on but have the old one .**** ..
Dec 23, 2009 | Sharp R-630D Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
