Question about Plumbing
Does not drain out final water from machine - Plumbing
  • 302 Answers
It could be either something is stuck under the pump/drain covers or there is buildup in the pipes.
Try running some dishwasher cleaning fluid ( found at most stores in the dishwasher detergent section ) in it.
You could also use a shop vac to try and suck out the built up grease etc.
If that doesn\'t work, you may need to take the covers off ( found in the very back of the machine, behind the "blade area" ) and check to see if some large pieces of food or other material has gotten through and is blocking the pump area.
Posted on Nov 03, 2013
No water drain on drain/spin cycle
clean the filter
check the pipes to the pump
Feb 07, 2014 | Kenmore Washing Machines
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
My machine still has water and the final cycle
CHECK TO SEE IF THE DRAIN HOSE IS KINKED AND NOT LETTING ALL THE WATER OUTSOME WASHERS OPERATE ON THE TIMER FOR DRAINING AND THIS WILL SLOW THE DRAIN DOWN CAUSING THE WASHER TO HOLD WATER
Aug 10, 2009 | GE Washing Machines
Washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Mar 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Help Guru Please
Ill try,
first off its normal for water to spray in during the final spin( its a spray rinse), as far as the water coming back into your machine after the final spin stops, you have an issue with oyour drain, i would assume that the drain hose is NOT going into a stand pipe"open drain", but instead clamped to another hose leading outside or to a drywell, in which case youll need to install a "one way check valve". whats happening is after the final spin is done al;l the waterin the drain line is reurning back formn the drain hose.Proper insstallation will cure this.
lastly its hard to describe"slower than usual spin" it will progressivly spin faster as moire water is removed form the machine, i wqould rectify the drain issue before i concern my self with this( and make sure you not selecting a :gentle spin" option of coarse... hope this is helpful to you!
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Plumbing Logo
48 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
