Question about Echo 2-Cycle 25.4 cc Straight Shaft Gas Trimmer SRM-266
Got a Echo 266 weed trimmer from my boss that seized up. Straight gas was put into it after only second use. I got it to turn and compression seems good and it sparks but still won't start. What do i check for next? Thanks...
    Sergeant:
  • 342 Answers
Sal check by putting a tiny bit of fuel in the block and see if it fires. It may need the carb gaskets changed
Posted on Oct 13, 2013
4 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Echo weed trimmer only run with choke half on
Check the fuel lines for breaks. When they get old, they become brittle.
If this doesn't work, you will need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. Use a Den Tek Brush,(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in the carb. Make sure the small screen is free of debris. Reassemble and start.
If neither one of these solutions work then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Posted on Jun 09, 2009
  • 1126 Answers
SOURCE: i need an instruction manual for echo srm 225 weed
http://www.echo-usa.com/documentation.asp?Model=SRM-225&lang=E
Hope this link helps.
Posted on Sep 08, 2009
hunter19_46m
  • 7482 Answers
SOURCE: ECHO Model 2100 weed trimmer will not run at full
Hi theroncro549...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Aug 15, 2011
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
this is what happens when someone run straight gas in two cycle engine
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
The starter pull cord on my gas trimmer will not pull.
Hi Mark
Perhaps a bit late now.... Just spotted this so I imagine it's all fixed by now.
But for others with this sort of problem.
Assuming the pull cord is not broken, stuck or tangled. Switch off or short plug to ground, for safety then remove the spark plug to allow the engine compression to escape. You should be able to turn the engine over really easy with the pull rope, otherwise the engine might be seized or the rotary pull mechanism jammed.
Also... can the shaft to the string line be rotated as in the crankshaft of the engine.
Good Luck
Aug 30, 2014 | Echo New String Trimmer SRM-225 2 Stroke...
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
no not fly wheel maybe coil if not sparking check switch fist is on for sure or bad plug coil expessive try squrying some starting fluid in the carb check compression has to be above 90lb to start check and see if carbon has block exhaust port do all this first
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I cannot remove string holder from my Echo weed eater. I push down, turn it to the left, but it will not release.
hi jhhorn, don't push down while turning. just turn it till you hear a click then pull it straight out
Jul 18, 2011 | Echo Garden
Husqvarna vs Echo gas weed trimmers...needing your opinion.
They are very reliable brands stihl is a very good brand also.
Jul 19, 2010 | Husqvarna 28cc Gas Line Trimmer
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Echo 2-Cycle 25.4 cc Straight Shaft Gas Trimmer SRM-266 Logo
165 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
