Question about RCA CC4352 Camcorder
I have an old RCA Camcorder Model CC422 that has no power. I need to remove a VHS tape from the recorder but the compartment door will not open.
4 Suggested Answers
techman007
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
LongPockets
  • 1177 Answers
SOURCE: How do I upload my
You can get videos from this camera, or any analogue video source, into a computer. You just have to play them into an analogue video interface port. These are available as expansion slot cards for a PC, or sometimes as a USB plug-in interface. They will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
Posted on Jan 14, 2011
suetv123
  • 26 Answers
SOURCE: I have borrowed an old
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
Posted on May 16, 2011
I have borrowed an old rca vhs camcorder inhopes of converting 4 vhs tapes to dvd. I have a Pinnacle systems DVC 90 to plug from RCA to Computer. I cannot get to cam to open? I charged the battery but...
May 15, 2011 | RCA CC-439 Camcorder
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Conversion vhs to dvd
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Mar 26, 2010 | Video Cameras
Camcorder won't record
Dec 27, 2009 | RCA CC6363 Camcorder
Tape will not eject may be in wrong how do i get it out manually
Open up the door and push the tape in hard and fast. Hopefully it will popup a little to remove it.
Is this an old cassette? If its damaged in any way, or it's been exposed to moisture or extreme heat, it can cause the tape to jam.
If that doesn't work and knowing that this Camcorder has no repairable parts inside, remove the door and turn the load gears in reverse. If this doesn't work, you might need to pry it out. I still have my ancient VHS recorder and had to do that once about 13 years ago. lol
It still works, but I bought new tapes. I'm not sure if those tapes are still available but you could search online for those.
I hope this works!
ps. Just in case you've lost the original User Manual I've attached a link below!
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000029241.pdf
Oct 25, 2009 | RCA CC6263 Camcorder
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
Need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Oct 29, 2008 | RCA CC6263 Camcorder
Recording issue
if it is really old there might be a switch on the front under the little door to switch record speeds.
Apr 24, 2008 | RCA VR615HF VHS VCR
Record from a VHS player
This is an easy one. It took me a while to figure it out too. You are on the right track but you need to use the remote control. You will go from record/pause to record and of course you have to use the mini to triple RCA cable that comes with the camera. I can't remember if there is an internal setting in the menu that needs to happen but I don't think so.
Videoteacher
Jan 07, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
RCA CC4352 Camcorder Logo
Top RCA Video Cameras Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
ray gallant
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
