Question about Tomtom Tom Tom RDS-TMC Traffic Receiver (9V00.080)
Tom tom screen does not work - Tomtom Tom Tom RDS-TMC Traffic Receiver (9V00.080)
I turn the power on but only the orange screen comes on with tom tom one on the screen. Screen not changing at all
If you turn on your tom tom gps device and the only thing that comes on is the tom tom display screen, then you need to reset it first. To reset it, what you have to do is to hold down the power on/off button for about 15 seconds and that will reset your tom tom, if it does the same, then you have to reinstall the tom tom application on it.
To reinstall its software, you connect it to a computer then it will detect the device, then the latest software downloads will come up, download it on to your gps, now when you plug it into your car and turn it on, it will get passed the tom tom display screen and start up normally.
Hope this information helped.
Dec 23, 2010 | GPS
The green power light on my tomtom XL is on and is fully charged however the screen wont turn on and remains black, it also makes no noise.
First you need to check if the battery is okay, try it on another tom tom gps receiver, if it is working and the screen wont turn on, then it means there is a hardware problem, probably the flexi ribbon that is connected to the screen is either loose or bad, this will require you to disassemble the tom tom and check for the flexi ribbon that connects to the screen, then you resit it or change the ribbon, that should do the job.
You can also try to reset the tom tom first before disassembling it. By pressing and holding the power on/off button for about 15 seconds, if that does not do the job, then you can go ahead and disassemble the tom tom.
Hope this solution helped
Dec 22, 2010 | Tomtom ONE XL-S GPS
The Tom Tom screen has gone black. It worked Ok on
If I knew the model I could help you perform a hard reset as the first step to recover it. Antonio Cesar Brazil
Jan 14, 2010 | Tomtom GO GPS Receiver
Tom tom was working in the car while driving. The tom tom stopped
There is a small hole on the tomtom device base. Inside it there is a reset button.
Press it and turn device on.
Try to turn it on while connected to the electricity, if it is a battery problem it should work
If it doesn't work I suggest you to bring it to a tomtom support center.
Jan 01, 2010 | Tomtom ONE XL GPS
Tom tom screen dark and flickers
Sounds like it is defective, try and contact tech support and have them send you a replacement.
Aug 22, 2009 | Tomtom Go 730 GPS
Tom Tom Go 730
trying to find how to got pin tom tom go 730
Jun 27, 2009 | Tomtom GO 910
Problem with tom tom 520
Do a soft reset by holding the power button down for 15 seconds. then power on and off. it should work. It did for me. if not, call tomtom. they are willing to help quickly
Feb 09, 2009 | Tomtom ONE GPS Receiver
Tom tom 3
This is a battery save setting.
Check settings under Battery Saving Preferences, choose Never Turn Off Screen
Apr 03, 2008 | Tomtom ONE GPS Receiver
Tom Tom ONE Version 3
Have you tried resetting the unit? Does it do the same thing after being reset?
Nov 25, 2007 | Tomtom GO 910 GPS Receiver
Tomtom Tom Tom RDS-TMC Traffic Receiver (9V00.080) Logo
24 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
