Question about Case Logic Bluetooth Mini Mouse - EBT0
Case logic ems-800 mouse works then computer doesnt recognize device
Free driver download for logic world precision optical mouse
world precision throwing me off
according to amazon
logic world mouse of any type
dont require a driver
if USB computer should automatically pick up the driver
check device manager and see what mouse driver is being used
if wireless .......even if you .have you lost the driver disc
computers will recognize the usb plug
Mar 31, 2017 | Optical Mouse Computers & Internet
Need to be able to connect to my computer . plugged it in but computer does not recognize the mouse . red light is on
My computer doesn't recognize my mouse and its not listed in ...
www.tomshardware.com > ... > Windows 2000/NT
Tom's Hardware Guide
Mar 25, 2012 - 9 posts - ‎7 authors
please help.....I am using my keyboard to move my mouse keys and it really sucks. After a storm everything came out fine on my diagnostic ... My computer doesn\'t recognize my mouse and its not ...
Feb 28, 2013
Mylaptop doesnt recognize the usb for my mouse ...
Jan 27, 2013
Computer won't recognize keyboard or mouse - Mice ...
Aug 27, 2012
Computer won't recognize keyboard or mouse? [Solved ...
Aug 6, 2011
More results from www.tomshardware.com
Mouse doesn't work in any USB port - Tom's Hardware
Jan 21, 2016 | Onn Optical Mouse
How do you turn this on, or are the batteries dead?
'finding' the mouse just means that the receiver portion has been recognized and drivers installed.
on the bottom of the mouse should be a very small on/off switch, and of course the batteries in the mouse might be depleted as well.
Sep 13, 2014 | Case Logic Wireless Optical Mouse Black...
Logik wireless scroll mouse
The mouse is listed as working with Windows 7 so you shouldn't have any problems using it in Windows 8.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Dell D620 USB device not recognized
Call Dell customer Support Number 1-800-204-4427 if your dell laptop, computer, printer and tablet facing technical problems. Our dell technical support experts will help you out within no time.
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
May 23, 2017 | Dell Latitude D620 Notebook
My case logic mouse does not show up in the "find devices" area. batteries are brand new. I just want it to work.
I tried searching case logic's site for support for this mouse...but to no avail. Apparently this was a hit and run product they never looked back on. Anyways, I found a few answers from other users on the net. Here's one such solution I could glean. Hope it helps:
1) Locate the 'reset' button on the bottom of the mouse. (Tiny little black button on ours...)
2) Plug in the USB receiver. The blue LED button should light steadily.
3) Turn on the mouse. Hold it near the USB receiver.
4) Push the blue LED button on the receiver, and as it begins flashing slowly, push the reset button on the bottom of the mouse. This should synchronize the mouse and the USB receiver within moments.
5) If the blue LED button on the USB receiver begins flashing very rapidly, the mouse and the USB receiver are communicating, and the mouse should begin to work.
If it does not, the battery in the mouse may need to be removed and replaced, then the whole process started again...
If it works, you'll probably have to go into Mouse Properties in your Device Manager and adjust the response of the mouse, because the default settings are often positively crazy sensitive!
Mar 11, 2011 | Case Logic Computers & Internet
My case logic optical mouse will not link up
Is this a wired or wireless mouse?
If this is a wired mouse, try connecting it into different USB port or different computer so that you would know if there's a problem with the USB ports or with the computer or with the mouse.
If this is wireless, try the following:
1. Replace the batteries of the mouse.
2. Make sure that the mouse is turned ON.
3. Try connecting the USB wireless adapter of the mouse into different USB ports.
4. Connect also the adapter into different computer.
5. Make sure that there's no interference between the adapter and the mouse such as wireless phones, cell phones and other wireless devices.
Wireless mouse, cordless phones and cellphones are all running at 2.4Ghz frequency, so if there's a wireless device that's running on the same wireless freq, then it would interfere with the mouse that would cause the mouse not to work.
If same problem occurs after checking everything, then contact the manufacturer of the mouse for RMA (repair).
Have a great day!
Sep 21, 2009 | Case Logic Computers & Internet
My S.O. Vista x32 doesn't recognize my mouse optical labtec 800
you can check your usb driver
it's work or not
you can go to control panel after that system device and hardware
and check proper install or not
Sep 20, 2009 | Labtec 800 Mouse
Case Logic Bluetooth Mini Mouse - EBT0 Logo
364 people viewed this question
Top Case Logic Computers & Internet Experts
Lawrence Oravetz
rdjagger
Are you a Case Logic Computer and Internet Expert? Answer questions, earn points and help others
