Question about Samsung LTN1535 15 in. HD-Ready LCD Television
Tv Dead when the on button is turned on only the small yellow light comes on but no high voltage or screen
    Sergeant:
  • 280 Answers
This is power supply or Inverter board
Check all caps in power supply some may be mushroomed at the top
Posted on Feb 21, 2008
Relay clicks when applying power. Yellow light comes on. TV is dead otherwise. Power supply is outputting +5, 12, and 24 volts Mainboard (3647-0282-0150) has +5 and 12 volts always applied. Checked...
Amber light on means standby voltage is high. IF amber light does not go white when power button is pushed the its one of two things.
A. No power on command from main board. Usually labeled PS-On. Should go high from 3.3v or maybe 5volts. If not present Main is defective.
B. If the ps-on line is going high then your problem is a defective power supply.
Oct 15, 2013 | Vizio XVT472SV 47 in. HD-Ready LCD TV
Red light on tv flashing.Tv will not come on when power button is pushed.Beeping noise heard coming from tv
This tv have a dead "H" horizontal High voltage output transistor.This transistor sit outer wall of the FBT-the flyback tranformer a big block of plastic with a red wire with a cap hook to a CRT-(tv tube).This tv should be repair by a professional,because "H" high voltage transistor are hard to find these day.Because of discontinue parts for tv CRT-(tube design).
Feb 08, 2011 | Philips 30PW9100D 30" TV
I have a Hitachi Ultra Vison 57S700 2004 model, the TV has had a slight high piched whine for a couple of weeks and today the screen went green then black and the sound was gone. When it is turned on the...
This tv is under five years old?Yes,it is worth fixing.Over five,i would compare the prices for a new LCD tv and the quote priced from the Tv Tech.for the old tv.This tv have high voltage problems around the Deflection circuitries area.Could be any things burn in this area.The high pitched whine sound,i'm sure it is from the FBT-the high voltages flyback transformer,high voltages current have no where to go.Must hire a tv tech. to troubleshoots and replace parts on the Deflection circuitries area.Also the FBT could be dead too,because HV Current bounces back forth and have no where else to go.The prices to troubleshoot unknown problems is about $400 bucks and plus cost of replacement of parts.
Dec 04, 2010 | Hitachi 57S700 57" Rear Projection HDTV
My Magnavox tv is about 5 years old. When we turn it on the screen is blank. A soft high pitched sound comes out of it. The green "on" light blinks on and off. Any ideas on what is happening and why it...
You have a bad eeprom. Very common problem for this TV. The replacement eeprom [location, IC002, on the Tv board] is dependent on which microprocessor [location, IC001, on the TV board] and which stereo decoder [IC 1001] are present on the board. See if IC002 has a color mark on it. red, yellow, green..etc. Or give me the numbers on the actual IC 001 and Ic1001. For example IC 001[ microprocessor] might beMCU A22V01-TO and IC 1001 [stereo decoder] MSP3440. Take this info to a TV tech if you cannot repair this TV yourself. Thanks for asking and give me a High Five of hands!
Sep 14, 2010 | Philips Magnavox 27MS343S 27" TV
I turn tv on, and the lights come on. then it turns off? screen does not come on. what could that be?
Ur high voltage is dead,FBT,flyback transformer is dead,the block of plastic with a red wire with a cap hook to the CRT(tv tube).
Oct 05, 2009 | JVC AV-32D305 32" TV
32 in ge tv doesn't turn on
It ur high voltage is dead.Ur FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to ur CRT(tv tube).That must be replace.
Sep 24, 2009 | GE 32GT740 32" TV
I have a sony vega 32" fd trinitron i turn it on and the screen is black in the right corner there is red light that says stand by timer. how do i get thr screen back on?
Ur high voltage is dead or dying.The FBT call the Fly Back Transformer is dead or dying.U can tries unplug the tv about an hour,might get the high voltage back temporally will happen again later.The big block of plastic with the red wire with a cap to ur CRT(tv tube).That ur prob.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Shuts off
sounds like the high voltage transformer
or could be high voltage off the tubes.
not a good idea to keep this running as it will cause more damage, best to have service tech look at this since it's high voltage.
Be careful. This same problem burned a mark in the Blue crt on my pro730HD. Three months and the Service Tech and Pioneer have been unable to determine the cause (they claim). In the process they have blown two more crt's.
When your tv goes off, try turning it back on using the main power button instead of the remote. The button should be behind a flip-down strip below the screen. When it is working again, look for any faint colored spots in the picture most prominent on light backgrounds. Mine is a yellow Y in the center of the screen.
If there are no spots, I would suggest you don't use the TV until you get it fixed because eventually it will damage your crt ($750). Of course, as I said, they have been unable to fix my problem and I have had no TV for three months.
Nov 21, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
My TV screen has no picture
If the light goes out you definitely have a short somewhere. If it blinks you have a fault, probably in the High Voltage circuit. Most common problem is a shorted Horizontal Output Transistor. Unless you are an experienced technician you probably need to have a reputable repair facility look at this one. Most will give you an estimate for free or for a small fee which will be deducted if you decide to have them fix it.
Jun 19, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Samsung LTN1535 15 in. HD-Ready LCD Television Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
