Question about Acer TravelMate 240 Notebook
I need to use a projector with my Acer TravelMate. I cannot get the laptop & projector to talk to each other. Also the Fn & F5 don't toggle between the screen & projector.
  • c_storm69 Apr 24, 2009
    Thanks, got it working now.
Try replacing the cable between the projector and your pc. Hopefully that's all it is.
Posted on Apr 24, 2009
Model acer travelmate 4000 nodisplay on lcd and external monitor
You say the trouble is with the keyboard. Can you attach an external keyboard via USB and see if you can push Fn key with F5 (I think it is the F5 key - try Fn with others - keep Fn pressed and repeatedly press the F5 or F6 etc.) several times to see if the screen toggles between LCD and external monitor. For this to work you will have to restart the computer after attaching the external keyboard. Press the start button until the computer goes off, and press again to restart.
Itf you ascertain that the trouble is with the 99.N7082.01D, make sure to try to fit it in correctly, or perhaps the Fn key has some dust or liquid in it so it does not function. Then you have to try to clean it from the inside after you disassemble.
Jan 07, 2011 | Acer TravelMate 2300 Notebook
TravelMate 3270-6569 (LX.TH706.051) PC Notebook: My acer travelmate 3270 is connected to a sony dat...
Try holding down the Function key (Fn), then pressing F5. Wait a few seconds. On most laptop, each press of the F5 key will toggle between laptop display only, projector only and Dual (same image on both - my favorite).
You'll probably see a little Monitor-shaped icon on the F5 key. It's possible it's another function key - on Dells it's usually F8.
Aug 02, 2017 | Acer TravelMate 3270-6569 Notebook
I have an Acer Aspire netbook that I want to hook to a projector. I finally got the right cord to hook it up, but it will not display on the projector screen.
One of the F keys will toggle between the Laptop Screen and the VGA output - look at the F keys and see if one has a picture of a screen often F4 / F5 - needs to be used with the FN key
FN key+ F4 Key (Or which ever key has the symbol on)
It will toggle between <laptop screen only><laptop screen and VGA output><VGA output only> Not necessarily in that order
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
Cannot connect acer aspire one to projector. it's first detected when netbook is booting up but the connection dispappears (no input on projector) when the computer is fully on.
It should be a keyboard toggle to switch display to the projector, usually Fn + F5, sometimes you have to tap the F5 key a couple of times for the display to switch over.
Good luck
Jun 19, 2009 | Acer TravelMate 2300 Notebook
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Attaching to multi media projector issue.
A Function Key cpmbination is driving display choice: on my Acer (travelmate) is FN + F5 on your model could be different (On Compaq 6710 is FN+F4)
Check your manual or your keyboard for function symbol (Blue marked).
Allow time to perform a switch
Jan 04, 2009 | Acer NSK8458AN Keyboard
Useing note book with data projector
connect through the vga port of the laptop, then press Fn key and the key mark monitor on your laptop, F5 together
Oct 21, 2008 | Acer TravelMate 3260-4542 Notebook
Acer travelmate 4200 'F5' key not working
Following an advice in this forum I loaded the launch manager for the travelmate 6592, installed it and It put working on the silver P key of the laptop, i.e. the launch manager, and at the same time the fn+F5 key started to working on again. For a long time this key was disappeared from me laptop, just the same time that the fn+F5 key didn`t work.
Jan 01, 2008 | Computers & Internet
Acer TravelMate 240 Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
