Kelvinator smart drive 5.5 pride. Water starts and stops a few times then machine stops and starts beeping, wash, rinse and spin lights all on. Has to be unplugged from wall before it will stop. Can anyone help please?
  • 249 Answers
SOURCE: Smart drive Pride 5.5
can you empty the machine completly of water, and start again.you could try unpluging it for 2 mins it might reset it self best of luck!!!,close,eire
Posted on Dec 15, 2007
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Posted on Jan 11, 2008
  • 1294 Answers
SOURCE: fisher & Paykel Smart Drive 9 Pride
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Mar 13, 2008
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9 won't spin
There's something wrong with it. It sounds like its broken and needs to be fixed.
Nov 08, 2013 | Fisher and Paykel Washing Machines
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
My Kelvinator pride 5.5 Smart drive 8 washing machine started beeping. It had one green light and one red light error message. I tried to get it to start, and it just hums. I removed all the clothing and...
I would remove the water outlet pipe and lay it as flat as possible to drain the remaining water out you will be amazed how much water there is left in the machine
the humming will be the inlet water valve or the motor trying to start when you have the door open try turning the drum by hand to see if it turns easily eric
Dec 26, 2017 | Fisher and Paykel Washing Machines
It dose not go to spin
Hi just read your posting.Now just a couple of questions.Does your machine drain the water If it does not drain the water remove most of the water by hand so you can tip the machine back so you can look underneath .Now you will see a pump to the front right of the machine.It will have a red or black fan attached to it.Turn the fan a few times to loosen the pump if it is tight .If it loosens when you turn the fan put it back on its feet and select a spin cycle and push the start button.Hopefully it starts to drain.If it drains it should spin. Please reply with additional information or if it starts to drain.Good luck.
Jun 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Excellence smart drive fills up with water and then doesn't wash
Hi just read your posting. Now when the machine stops does it sound a beeping sound and a series of lights light up? If it does starting from left to right I need to know what light have come on in the row of 8 lights.Is it the 1st and 5th or 3rd and 7th etc.Please reply 4 further help.
Jun 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Aug 05, 2008 | Washing Machines
Dec 15, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
