Question about MGE Galaxy 3000 UPS System
I am unable to change keyboards, or change settings
    New Friend:
Try this site
Posted on Oct 20, 2013
Enable keyboard
First, make sure it is plugged in. If it is a USB type, try the other USB ports on the computer to see if one or more ports have failed.
Still no luck? Try differen USB ports each time you boot up. During the boot, enter the computer's BIOS or Set Up area (usually pressing DEL, F1 or some other key). Check for setting regarding keyboard and keyboard type. Make sure they are enabled. If nothing works, the keyboard may be broken - not disabled. Try with another keyboard instead.
Apr 09, 2014 | Computers & Internet
Keyboard symbol does not match typeface
the keyboard language you have set does not match the hardware - you have a UK keyboard but US settings for instance. - change the keyboard language in control panel to fix the problem
Jan 26, 2014 | Computers & Internet
Unable to unlock keyboard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
click start control panel administrative tools computer management device manager scroll to keyboard you could see a yellow/question exclamation mark? ! or a red X right click to install drivers
click start control panel keyboard hardware then properties you should see driver details and have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
hope this helps you
Oct 08, 2011 | Micro Innovations (09N5545) Keyboard
Iam using inspiron 5010 i5 core laptop, m unable to type greater than or less than signs from my keyboard its showing other symbols, i have windows 7 as my operating system, help me as soon as possible
Hi Faiz,
The standard keyboard language and widely used setting is "ENGLISH (US)"
Set the Keyboard layout to English US so that you have standard keys for symbols etc. like @ sign with SHIFT+2 etc.
The keyboard layout / Language of your PC may have been different (other than English US), so follow these steps to select the International keyboard layout:
- Go to Control Panel - Regional and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
(The above illustration is for Windows XP, but you would find similar options in Windows 7 as well)
The above steps would change the Keyboard Layout settings to 'English US' and you would be able to type @ sign with SHIFT+2 and with SHIFT+. etc
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 18, 2011 | Dell 0Y3740 Keyboard
Laptop top keyboard will not function appropriately unless Dynex separate keyboard is used. I am unable to identify the Dynex device to uninstall. First listed states Std 101/102 Keyboard and the other HID...
Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
May 27, 2010 | Dynex Multimedia Keyboard
Unable to log onto computer keyboard double spacing and double ch
Try a different keyboard, if a different keyboard works properly then your original one is defective. If another keybaord does the same thing then its a setting in the operating system for the keyboard that needs to be changed.
May 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Would you please advise how to adjust the brightness settings.when i go to the menu button i can get the various settings but i am unable to make any changes.please advise. thanks
Hi; the upper part of your keyboard closest to the screen or the last row of keys contains a BRIGHTNESS key...
Press and hold the Fn key (usually italic and purple color) and press the Brightness (sometimes depicted by a bright bulb) key and observe if there's a change in brightness...remember to hold down the Fn key while adjusting the brightness. I hope this helps since you did not mention computer type or keyboard arrangement!
Jan 23, 2010 | Hyundai Computers & Internet
I have just updated to windows 7 and seem unable
Windows 7 is different, get used to it. Your old keyboard is probably not supported.
Oct 24, 2009 | Microsoft Wireless Laser Desktop 4000...
Keyboard problems
Is the keyboard flexible cable the same pin as the original keyboard? If yes and you are sure the new keyboard is okay, then you can change the language to the preferred language e.g US English, change its position to the first and make it referred. Its should work. You can also check online if there is any keyboard or input driver which when installed can be of help.
Apr 12, 2017 | HP OmniBook Vt6200 Notebook
Unable to type question mark i getÉ colon è
Nothing. You just need to change the keyboard layout. For help Start > Help and support > (type keyboard layout) and press enter.
Aug 25, 2009 | Toshiba Portege 3500 Tablet PC
Computers & Internet Logo
47 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
