Dryer furnace and water heater not heating up, are they related to eachother
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
Are both item gas? Is the water heater lit? Breaker switches on the same circuit in fuse box? More details please.
Posted on Nov 04, 2013
Does the water heater and furnance run on gas and electric?
If the units are in a RV then yes, they both may run on gas and DC (battery power). The furnace requires gas to provide heat and DC power to run the fan. A water heater may be gas or electric, but if gas, it requires gas to heat and DC power to ignite. If the water heater is electric it requires AC power to heat.
Oct 15, 2015 | Water Water Heaters
Won't heat after gas meter replaced
goto the dryer's manufacturer's site and click on support you should be able to download the owner's manual, the pilot light needs to be relight or the pizeo lighter is not working
Jan 26, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
We just purchased a home with a beckett heater. we cant stop it from heating the house, it is 80 degrees in here and the heater is off! its burning up oil like crazy but we are only in need of the hot...
Terry, most units like yours had a Winter and Summer setting. It should be located on the furnace itself. In the Summer mode, only the water is heated for domestic use and the furnace side of the system is shut down.
Apr 05, 2011 | Heating & Cooling
The burner lights runs for 2 to 3 seconds then goes out
If you have an older heater I would replace the thermocouple. They tend to burn out, as mine did on my furnace. Relatively easy to replace if you have any home repair skills at all. They can be purchased at any hardware store and come in different lengths. If not have a trained heating expert do it for you.
Jan 22, 2011 | Water Heaters
Every time we put on the central heating our water runs cold
What kind of water heater do you have?
In any case, it sound like a plumber should check out system.
Do you have indirect heater that gets heat from central heating boiler?
Most indirect/boiler combo heaters have control that is set to heat the water first.
If water is not getting heated, then the control needs repair.
Do you have gas water heater with gas central heating?
The central heater may be drawing so much gas from meter, that other gas appliances are unable to function. larger gas meter or gas line may be needed.
Or if furnace and water heater vent on same chimney, the backflow from central heat could be affecting burner on water heater especially if water heater has electronic sensor that stop combustion if air quality is bad. Venting problems can lead to CO poisoning, and are a serious matter.
Nov 18, 2010 | Water Heaters
No digital readout on home thermostat. No backlight either.
Turn the Furnace off, Disconnect the R and W thermostat wire from the control board located usually in lower compartment of furnace, the blower
is usually mounted behind it.
Make sure the 2 wires you disconnect are going to
R(usually power) and W(usually Heat) other terminal
markings are y(for cool) g(for fan). After Disconnecting the R and W wires Turn the furnace
back on. You will probably have to hold a door switch
in to complete the circuit. If everything is correct the
furnace should not run.
This is more than likely that you have the R and W
wires touching eachother and you need to get them seperated.
Jan 05, 2010 | Heating & Cooling
Arcoaire heating/air conditioner continually cycles condensation
a possible solution is to install an air dryer in line with this tube
Jan 03, 2010 | Calvin Klein The Field Controls Company...
My Model TH8320U1008 touchscreen not working. I have replaced the batteries, still doesn't work. Is there a way to reset it?
I dont think its your thermostat. The 8000 pro series is relatively new. I think is you furnace you lost 24 Volt power. Check the furnace out first. www.fastacservice.com
Oct 18, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
