Question about Dell Alienware X51 AX51-5722BK Desktop PC Windows 7 Home Premium
So my computer has been freezing up every now and then. Its normally when I take an action such as right click. And its only happening after a few hours of it being on. It started happening as soon as I switched Internets. (Not sure if its linked to that or not. And also my PCI Express is failing. Error code: WPE01-ETZ. Again I'm not sure if any of these two things have anything to do with it.
    Sergeant:
  • 252 Answers
Check it in safe mode, in safe mode your computer should run proper. if it is then reinstall the OS otherwise some hardware issue is there, check with the single RAM.
Posted on Oct 12, 2013
  • FatStefano Oct 01, 2014
    I know this is old, but I wanted to list what I did to solve this problem, should someone else have the same issue. I too have a Dell POS Alienware computer. After 1 year of constant freezing, I found the culprit. So - if you notice, the INSIDE SIDE OF THE CASE (bottom left corner if you are looking at the SIDE OF THE CASE THAT COMES OFF) that comes off has this little metal connection that rests ON THE INSIDE of the CASE and appears to touch the POWER SUPPLY or something. After removing THE LITTLE PLASTIC METAL CONNECTION and cutting the wires so it is no longer on the INSIDE/BOTTOM of the INSIDE case and touching the POWER SUPPLY connector - I NO LONGER HAVE ANY ISSUES. NOT SURE WHY this is there, maybe it's there so you have to have the case cover on before you power the PC, but after removing that I NO LONGER HAVE ANY PROBLEMS. 1 week of running with no issues and this is the only thing I did. So - in a nutshell, this solved it for me...no more issues!
4 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: Dell OptiPlex GX260 PC Desktop keeps switching its self on !!!!!!
Check the pwer settings on Desktop-properties-screen saver- power options and set it from there. Disable Hibernation......sodeep
Posted on Mar 22, 2009
haystack11
  • 55 Answers
SOURCE: when i click on send to computer freezes
Either you are running low on pc resources such as ram (memory), hard drive OR you have a virus.
1. You could try doing a "system restore" and go back in time to when it worked also.
2. Try to do a complete virus scan. AVG free edition of coarse is free.
3. Buy some more pc memory.
Posted on Sep 17, 2009
Testimonial: "thanks have loads of memory fault now gone was either system restore or back to default appreciate your help"
  • 4961 Answers
SOURCE: error code 0147 spindle test failed
The error you received (2000:0147) indicates the drive has failed. It cannot be fixed. You need to replace the drive.
Posted on May 29, 2012
Toshiba satellite L675 freezes after startup. Windows &
Boot the computer into "Safe Mode".
To boot PC into Safe Mode follow these steps:
1. Turn the computer on or Restart the computer
2. Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
3. Ensure that the Safe mode option is selected, not Repair Your Computer
4. Press Enter. The computer then begins to start in Safe mode.
5. When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If the computer boots into Safe Mode you can try disabling Startup Programs, one of these might be causing your computer to freeze. To do this follow these steps:
1 Press Start. Type msconfig into the search bar and press Enter. For XP, click on Run and type msconfig there.
Mar 30, 2011 | Toshiba Satellite L675-S7062 Notebook PC
Tip
How to Check your Computer when a Page Freezes
<p>1. Press the "Esc" once or twice and see if the computer returns to normal. If nothing happens, press a few times. If your computer does not respond, try the next step.<br /> <p><br /> <p>2. Press "Ctrl, Alt and Delete keys simultaneously and select Start Task Manager". Select Programs "End Task" to a status of "not responding" one by one and click OK. The programs should be automatically closed. If your computer is not responding to anything, press the button until the computer turns off.<br /> <p><br /> <p>3. Wait a few minutes before the computer. If the computer is in use for a long time, let cool before again. Overheating can some hardware components do not work anymore, because too much heat.<br /> <p><br /> <p>4. Deleting files or programs you no longer use, especially if the disk is almost full. When the computer tries to find a complete unit of information, they can freeze and become unresponsive.<br /> <p><br /> <p>5. The use of anti-virus software on your computer for malware, adware and viruses. Remove the virus. You can stop computer processes and cause a computer to freeze.<br />
on Jun 21, 2011 | Computers & Internet
Ok heres my problem when my computer comes on it says it wasn't shut down correctly and when i have it to start normally nothings happens it just freezes and when i have it start from last known working...
Most likely the driver that ha gone bad is the video driver. Let's troubleshoot the problem first by finding out if this happens on Safe Mode. Perform the following steps. Make sure the computer is off.
1. Turn on computer
2. Start tapping F8 key right away (once per second)
3. You should be looking at your screen with the Windows Advanced Boot Option menu similar to the picture shown below.
4. Use your keyboard's UP arrow key to highlight Safe Mode with Networking.
5. Press Enter key twice.
6. Log on to your account if prompted.
7. Click on Yes button to continue loading the Safe Mode.
8. Close any window that may come up on your screen.
In some cases, you may notice that everything seems to be in bigger size. This is normal on Safe Mode because it is using the native drivers for your computer.
If the computer freezes in Safe Mode, chances are, you might have a hardware problem. It may be the hard drive or video card. If the video card is integrated or built in to the motherboard, then it might be the motherboard.
If the computer does not freeze in Safe Mode, let us continue and hopefully resolve this issue. Perform the next steps.
1. Click on Start.
2. Right Click on Computer.
3. Click on Manage.
You should find yourself looking at the Computer Managment window.
4. Click Device Manager to highlight.
5. Click the plus sign of the Display adapters, similar to the picture below.
6. Whatever listed under it, delete it. Press the Delete button on your keyboard, then,
follow the instructions.
7. Restart Computer to Normal Mode.
While your computer is restarting to Normal Mode, Windows should be installing its Native Driver for your computer's video card/adapter. Eventually, you will need to re-install the video driver for your computer. Should you find yourself asking how to re-install the video driver of your computer, kindly response with your computer's brand/model for further assistance.
I hope this works for you. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 25, 2011 | Computers & Internet
My computer runs window 7 and it keeps shutting down for no reason and also it keeps freezes for sometime.
Reboot the computer in "Safe" mode and run it for a while and see if the same problems occur. If it doesn't, then I would suspect it is a software and not a hardware problem.
If you think it is a software problem, reboot the computer into safe mode again. Now click the start button and in the search box type MSCONFIG
When the window pops up click the "Selective Startup" button and then on the startup tab. Deselect all the checked boxes, click apply and ok, reboot the computer normally.
Now only the essential services will load and no programs will automatically load. If the computer continues to run normally, then you can go back into MSCONFIG go to the strat tab and start checking a few boxes to start again, like antivirus and malware first. Reboot the computer and see if it freezes with those programs running....if it does then you know one of those is the culprit, if not click a few more on and reboot until you find the trouble software.
Jul 01, 2010 | Computers & Internet
Clicking sound in computer then BSOD
There are very few mechanical parts in cpu...some of them are cpu fan. smps fan chassis fan hard disk motor or cd drive.......as you were talking about click...i doubt on cpu fan also clean the processor and coolant as there might be dust in it that prevent the cpu fan to cool down processor this might be causing system freeze....do reply back if this solves your prob
Oct 01, 2009 | HP Media Center m1270n (PP132AA#ABA) PC...
Acer Aspire 6930 freezes coming out of standby.
Hi
Go to bios setup then advance>IDE setup>change enhance to compatible your problem ll be solve
Harry
Jul 14, 2009 | Acer Aspire One PC Notebook
Autocad 2007 causes PC to freeze, may be graphics card related?
I feel you are right on target with the Video. I was thinking you could back off on video accelerator .
right click open area of the desk top-right click-properties-settings-advance-troubleshoot...
then take your slide about half way back and click apply and ok....
I would try and resteat the vid card and give the drivers another shot, if you can download them from another source such as major geek.com
hope this helps...please leave rating
May 12, 2009 | Autodesk AutoCAD 2007
Desktop freezes up so often or gets logout by itself & reboot?!
This could be a couple of things, overheating may cause it to randomly shut down, but if it freezes up on you then it could be a motherboard issue or memory. When you boot up your computer, does it beep at you at all? More than 1 beep signifies a problem. Right click on the my computer icon and click properties, see how much memory it says you have, does that number look accurate? A bad memory module could cause similar problems. A bad motherboard would, in my experience, more often freeze when you first boot up.
Mar 12, 2009 | Computers & Internet
LG SecurDisc Super Multi internal DVD not working properly
Dear Friend,
You can try this method, firstly u will do right click on my computer at desktop. here is method for doing this thing: right click on computer------->properties-------->hardware-------->device manager------>right click on your burner drive-------->properties----->driver------>uninstall. GO back to the device managger window, click 0n "action" and then on "Scan for hardware changes". The OS should find your burner and install back its drivers properly. right click my . GO back to the device manager window, click 0n "any drive" and then u will see a option on the bar at above "Scan for hardware changes". then click on "Scan for hardware changes", The OS should find your burner and install back its drivers properly. but if your internet is connected then it is very good. Then u will latest drivers & internet search & update the firmware also.
for any type of drivers u can check this website also: http://www.softpedia.com/ , here u will get any type of softwares @ totally free, you have no need to pay any thing.
Thanks alot,
Sanjeev Suri
Jan 02, 2009 | LG SecurDisc 20x Internal Double-Layer DVD...
Camera not recognised by computer
Open My Computer and see if the device is recognized. If so you can access it this way by double-clicking or right clicking and choosing the appropriate action.
Sep 13, 2007 | Samsung Digimax A400 Digital Camera
Dell Alienware X51 AX51-5722BK Desktop PC Windows 7 Home Premium Logo
150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
