Question about Chaintech MB |MBAV-MK8T890 Motherboard
User's manual i need to find the user's manual for my chaintech mk8t890 motherboard. it's a socket 754, phoenix bios, 2x184 pin ddr motherboard
  • Ken Mase Sep 27, 2007
    actually i already found it. thank you.
    Novelist:
    Scholar:
  • 167 Answers
I can't find a heavy manual but here is a link may be useful to you: http://www.hardwarezone.com/articles/view.php?cid=1&id=1834
Posted on Sep 27, 2007
Nead to replace my motherboard ga-k8vm800m
http://www.newegg.com/product/product.aspx?item=N82E16813128262
So you need a motherboard that has a Socket 754 processor socket, supports AMD socket 754 processors with up to an 800MHz FSB, uses DDR Sdram 400MHz ram memory, (PC3200), and has an AGP graphics slot.
From a quick search just now I see a lot of them listed on Ebay.
NOT advertising for Ebay.
I saw other listings on the internet also. (GA-K8N51GMF-RH - Way too pricey!)
Regards,
joecoolvette
Aug 07, 2011 | Gigabyte GA-K8VM800M Motherboard
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Motherboard Chaintech SK8T800, Windows XP sp3, BIOS = Phoenix AWARDbios v. 6.00PG. Does not work sound system.What can I do? Thank you very much
    hello, Try and get the sound driver for the motherboard,simply download it online by typing the model name of the motherboard in google.com and download the sound driver.Or if you can get the sound driver from the CD that came with your motherboard, if you have one?
    Nov 18, 2010 | Chaintech SK8T800 Motherboard
    Purchased Infineon 1gb ddr ram pc-2700 184 pin for my amd sempron processor 3100+ and it wont work it wont gent past the bios
    remove it,go to internet and find out what type of ram you motherboard supports,it's buffed or unbuffed,like registrated or not registreted,and thats way your ram won't work...
    Mar 13, 2010 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
    How can I reset password for Bios Phoenix? the problem is that i can't run windows also
    Try this, this is called "Backdoor BIOS Passwords" (manufacturers use these passwords for testing and maintenance.)
    Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
    OR
    Try removing your CMOS Battery. (Note that all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.)
    Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system.
    OR
    Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Power on your machine
    -jwma
    Jan 06, 2010 | Computers & Internet
    Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
    Form Factor: ATX (305mm x 200mm)
    CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
    Chipset: ULi M1689
    Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
    Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
    Audio: Realtek ALC850 with 8 Channels
    SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
    UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
    FDD: One FDD connector supports up to 2.88MB
    USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
    System monitoring: Two Temperature and Fan Sensors for CPU and System
    Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
    Turboc3 doesnot work in my amd motherboard with amd processor
    PC or laptop? socket 754 motherboard for Sempron, with the square hole in the middle with no pins in square hole?
    Jan 18, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
    Chaintech mk8t8990
    this will give you a place to start...... www.wimsbios.com/phpBB2/topic8557.html
    Sep 24, 2007 | Chaintech MB |MBAV-MK8T890 Motherboard
    Computers & Internet Logo
    227 people viewed this question
    Top Chaintech Computers & Internet Experts
    Mark Gough
    Alun Cox
    Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
