Question about Dishwashers
Dishwasher drains fine .but after a few days water builds up in tub.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Your drain line does not have a hi loop or your air gap is broken. The hose must never sag below the level of the disposal or the air gap needs cleaned.. here is a video to help..
http://www.diynetwork.com/videos/dishwasher-high-loop-hose/33822.html
this one is for the airgap
http://www.youtube.com/watch?v=rmG2JXQL858
Posted on Oct 13, 2013
4 Suggested Answers
SOURCE: dishwasher issue
Have had this problem twice on my DWI614. First time engineer came out and I watched what he did and asked questions. He removed panel at bottom of dishwasher (2 screws) after removing facia panel from kitchen as it is a built in dishwasher. To the right is the drain pump. Remove 1 retaining screw and hose retaining clip. Ease out the drain pump and make sure to have some cloth beneath as residual water will flush out. Before I did this the second time I removed as much water from inside with a small cup first. Both times I had blockages in the drain pump. First was a piece of glass and second some food. I also pulled the drain pipe forward and blew through to make sure path to sink was clear. Clear out and reassemble. Start a simple program before putting the front back panel back on and you can touch the drain opump and feel it working as the water drains properly. That was my fix both times, good luck.
Posted on Jun 17, 2008
  • 1382 Answers
SOURCE: Water wont drain out of bottom of tub.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Posted on Jul 07, 2010
marka19
  • 1430 Answers
SOURCE: water not entering dishwasher. Worked fine one
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Posted on Jul 21, 2010
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Tip
How to Sanitize Your Dishwasher
Step 1 -
Get rid of any odor that may be coming from the plumbing pips your dishwasher shares with the sink. Pour a half of cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all of the baking soda is washed away. After five minutes, run very, very hot water down each of the drains.
Step 2 -
Clean out your garbage disposal. Slice a lemon/lime and put the slices down your disposal drain. Run your disposal with cold water running.
Step 3 -
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process is that does not clean up all of the build and film. You can use baking soda and bleach instead of vinegar - just sprinkle the baking soda in the bottom of the dishwasher tub, and pour bleach inside the tub as well.
Step 4 - Between washes, pour 1/4 cup of lemon juice into the dishwasher cup and run a short, but complete wash cycle. This will not only deodorize the dishwasher but will also help get rid of any metal build-up.
on Oct 19, 2011 | Frigidaire Dishwashers
What would be the problem with our KitchenAid dishwasher mod....KUDLO21RBS4-ser. FU1001460....we have been having issues with it draining completely, had several repairmen in with no luck....the water
It sounds like you have a build up of debris in the bottom where the drain is. You can take apart the bottom and clear out all of the accumulation. Put it back together and it should drain fine. You could also check your drain hose and replace if necessary.
Oct 03, 2017 | KitchenAid Dishwashers
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
My dishwasher Bosh Model SHU43C06UC has the drain clog
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Apr 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher builds up stinky water in the bottom between use
you are back flowing waqter from your drain into your dishwasher make sure your drain are not clogged check your p trap to see if it clogged
Dec 11, 2008 | Neff 24 in. S5543X2 Built-in Dishwasher
Water In Dishwasher Won't Drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
a
Jul 13, 2008 | Roper 24 in. RUD4000M Built-in Dishwasher
Maytag dishwasher MDB9100A---tub refills after cycle completed
Problem is actually a water valve that is near the water inlet. Cost is about 35 bucks to fix unless you listen to the guy on here and pay for parts that you don't need and pay them 20bucks for bad advice. Our total cost to fix this $35 dollar problem was an entire wasted Sat, 2 trips to the appliance repair parts place, $130 for the electrical control board that the "wiz" here said I needed--electronic parts and non returnable so we now have a new one that we didn't need.
Mar 29, 2008 | Maytag MDB9100A Dishwasher
Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Sep 02, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
