Question about charter.net
How do I turn on the charter tv - charter.net
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
Jan 21, 2016 | RCA Televison & Video
How do I program charter remote to work with the Sharp Roku smart tv?
Hi Cathy.
If you go to this site
Charter net Charter Remote Controls 1060BC2 1060BC3 and put in Sharp as the TV type, it both gives you instructions on programming the Charter remote, and gives you the codes for Sharp TVs (10818, 10093, 10688, 10851, 11602, 12360 in this case)
Hope that gets you up and running!
D
Dec 03, 2015 | Sharp Televison & Video
Code For Charter Remote
Charter has a web site tat list the codes. Bit hard to find the url so you might call support
Feb 09, 2014 | Proscan 32LB30H LCD TV
My Vizio Bluetooth remote with keyboard has stopped working. I have spoken with Vizio tech supp. to no avail. I have a remote I used with my old TV issued by Charter because I have Charter cable. I want...
you need to contact charter for support on their remote and how to reprogram it for your new tv. for most universal remotes there is setup key or you have use a key combo to press to enter into setup mode and a user's for the cable box may have this info. however, if you do not have or did not get a user's guide then you need to contact your charter cable company for the info needed to get the 2 devices working together. refer to cable co. tech support.
Aug 25, 2011 | Televison & Video
I need a code for a TV remote for a GPX TV
Comcast sez the code for GPX tv is 10179
Jan 16, 2011 | GPX Televison & Video
I just bought a apex LD4688 46" flat panel tv and I can't get the charter remote to work with it. Anyone have any ideal what the remote code is for this tv?
Just call Charter customer service and they should be able to assist. I just had to do it for a Samsung I have. That is a bit of an off brand, so the Charter remote may not have a built in code available for that TV. Good luck.
Nov 26, 2010 | Televison & Video
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
Need the code for the charter remote for my vizio
For example, to search for a code for your TV:
  1. Turn on your TV.
  2. On the remote control, press TV once; it blinks once. Then press and hold SET UP until the TV key blinks twice.
  3. Enter 9 9 1. The TV key blinks twice.
  4. Press 1 (the device code digit for your TV). The TV key blinks twice. Aim the remote control at the TV and press POWER once.
  5. Press and release the CH+ key continuously, then stop when the TV turns off.
NOTE: In the searchmode, the remote control sends IR codes fromits library to the selected device, starting with the most popular code first.
  1. Press POWER. The TVshould turn on, then press SET UP to lock in the code.
NOTE: If the TV does not turn on during step 6, then slowly press and release CH- to go back through the codes, then press SET UP when the TV turns on.
Jan 12, 2010 | Vizio VO47L 47 in. LCD TV
I can not make my tv turn on with my charter communications cable remote and the tv is brand new
Go to this web address and post which of these remote controls do you have?
http://www.charter.com/customers/support.aspx?menuitem=2
Thanks...
Jan 04, 2010 | Emerson LC320EM9 32 in. LCD HDTV
charter.net Logo
Top charter.net Computers & Internet Experts
David Payne
David Payne
Are you a charter.net Computer and Internet Expert? Answer questions, earn points and help others
