Question about Bubble Magic 20 Gallon Mini Washing Machine
How to clean the inside "vents" in the bubble magic 20 gallon machine
INSIDE DRYER VENT FOR A MAYTAG ELECTRIC DRYER
I do not recommend venting a dryer inside. I suspect you are trying to save heat you have paid for. A dryer will add a lot of moisture to the area it is in as well as secondary lint that gets through the lint screen. This will cause condensation on any cool surface. In a basement this can lead to mold and mildew. But if you want you can make your own lint trap and if you need the humidity. Get a 5 gallon plastic bucket, some 4" aluminum vent pipe and 90 degree elbows. Direct the dryer exhaust into the bucket filled with some water. This will catch most of the secondary lint. Clean often and do not let the bucket run dry. There are some gallon buckets on the market that look a lot nicer but they restrict the airflow to much and this can cause problems with heating elements and thermal fuses. Never and I say Never vent a Gas Dryer inside.
Hopes this helps
Oct 19, 2014 | Maytag MDE16PD Electric Dryer
My Laser-73 ignited then warmed for a minute,thenflased EE2. I have replaced the filter and I have 150 gallons of K-1. What do I do? The heater tries to start then shut down, then I get the EE2
There are several possibilities. You said you have plenty of fuel, but is it getting to the fuel sump. If the pump makes a loud ticking or thumping sound, it is not getting fuel to it. You may need to vent your filter to remove an air bubble. The heater also has a strainer inside the fuel sump that may need to be cleaned. Refer to the owner's manual for instructions for that. The fuel sump also has a reset button that releases the fuel float that may need to be pressed. The fuel nozzle sometimes gets clogged with carbon. You can remove the fuel line and insert a piece of wire (stiff wire) into the nozzle about 1-2 inches to remove it. Another problem may be a dirty flame sensor. You can clean it with steelwool. Since you say it lit I wouldn't suspect the igniter is bad. Also remove the top from the fuel sump clean the sump if necessary.
Sep 21, 2010 | Rinnai Toyostove Direct Vent Heater:...
My son's bean bag pillow with beans exploded in dryer
The easiest way is to remove the front. You can then see between the inner and outer drum without removing the rear bearings and heat elements.
Jun 07, 2010 | Magic Chef CYE2000 Electric Commercial...
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
Cannot get gas to go down when pumping, clicks off, by not full.
The tank is not venting during filling--check for a damaged hose/line from the tank to the charcoal filter. Also check the large rubber coupling hose that goes from the filler end to the tank fitting for damage. Look inside the filler passage with a flashlight for an obstruction.
Check the computer with a scanner for any codes and pursue to repairs. It might be something to do with the fuel filler area.
Oct 08, 2009 | 2001 Jaguar XJ
Black carbon/soot on the door and lint filter of my dryer
Soot would mean lint is circulating around in your machine, and getting to the combustion area. Take the machine all apart and clean it thoroughly, including taking the cover off the fan and cleaning it too. A dirty fan will slow down the whole works. Check with your hardware store for a chimney-sweep's brush. I once bought one that could be tied to ropes and pulled up and down a flue. If they have a brush the right size, you could do that and really clean your dryer vent.
May 12, 2009 | Crosley CDG6000 Gas Dryer
Dishwasher won't drain water
The bubbles created by the dish soap could cause poor draining, but I would think it would just cause more of a bubble problem than a draining problem...
Either way, some people would say to throw a cup of vinegar into the wash area, but I prefer to just use water.
Disconnect the drain line from the machine at the sink and route it into a 5 gallon bucket. Drain and fill the machine several times to clear the bubbles out. This will also give you the opportunity to see if the drain problem you state is a machine problem or a drain problem.
Hope this helps,
Kermit
Aug 14, 2008 | Magic Chef 24 in. DU2000 Built-in...
My outdoor dryer vent leaves about a gallon of lent out on my patio and cedar storage unit every season. How do I trap the extra lint coming out the vent? I have tried cheesecloth, but I have to change it...
i'm sorry, but that happens with all dryer vents. you might consider rerouting the vent to another location. while you're at it the vent hose needs to be cleaned out, they tend to clog up and decrease drying efficiancy.
Apr 27, 2008 | Dryers
Bubble Magic 20 Gallon Mini Washing Machine Logo
Top Bubble Magic Washing Machines Experts
Are you a Bubble Magic Washing Machine Expert? Answer questions, earn points and help others
