Question about Microsoft Windows Vista Ultimate Edition
VISTA Strucks in the loading tab
I have WIndos Vista home premium, 64bit. it is not booting. i tried for HDD self test and memory test.. all seems to be good. but it is not at all booting.. i tried to boot in safe mode. it works good. then i tried to change the msconfig but nothing worked to boot normally. then i reinstalled Vista,, still it is not booting.. actually it strucks in the horizontal tab which loads the OS
  • 3 more comments
  • ksenth16 Apr 24, 2009
    I disabled all the service except Microsoft services. even then the system is not booting in normal mode. but it is booting in safe mode. i re installed vista. the horizontal tab which i mentioned is the first loading bar which comes with "Microsoft Corparation"
  • ksenth16 Apr 26, 2009
    Thanks a lot for all your advices.... i checked the Even log.. where i saw the WMI application is stored as error. How to over come this?
    in the Event Log i got another error with the DCOM. event ID 10005
  • ultimitloozr May 11, 2010
    Check the Event Log, especially the System log looking for any error and warning messages. They should direct you to the driver or service that is causing the system to hang. If that doesn't work, use MSConfig to enable Boot Logging and restart the computer in normal mode again. After the system hangs, restart in Safe Mode to review the log that was created during the boot process. It should indicate what it was trying to load/start at tht e time the computer stopped responding again.
    Since the machine would boot in Safe Mode, you could have changed msconfig settings to give you nearly the same environment; that is, disable everything possible in msconfig. Rebooting normally would have given you slightly more functionality thatn Safe Mode, but not much. Then you should have re-enabled items in msconfig one-by-one until it failed to start again. The last item re-enabled would have been your problem child. So, you would disable that item again and continue with any remaining items. Or you could have rolled the system back to a previous checkpoint using System Restore (if it was enabled).
    Now, did you reinstall Vista or did you attempt to Repair the existing installation? And what do you mean by "the horizontal tab which loads the OS?"
  • 4 Answers
U are facing the problem because may be your OS is not able to load all the drivers needed for the normal mode.
Don't install your OS from the where u r installing till now. Use some other DVDs or IMages to Install the OS. If it works fien than u can ask for a change because it seems that the image u r using is corrupt.
-Arualld
Posted on Apr 24, 2009
Mahjong Titans (Windows 7) worked well until recently. Now, the initial screen loads, but when I select a layout, the initial screen stays on. I can hear the tiles dropping into place, but can't see...
try running winows 7 in safe mode, ie hit F8 on startup before windos stars then try to run the game, if it works in safe mode it could be the graphics card on the way out.
cheers
Paul
Aug 12, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Samsung HDD not seen by Vista I recently purchased a Samsung HD154UI Hard Drive for my Vista 64BIT System. I have enabled the hard drive in the Bios. I now have a 500GB drive on SATA 1 and the new...
This won't be the best solution for you perhaps because I'm not a windows guy, but download the gparted (just google for gparted) cd image, burn it to disk and boot it up. Use that to partition and format the drive.
Aug 05, 2010 | Microsoft Windows Vista Home Premium...
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Window vista low memory error
Sir,
For Vista installtion there is 512MB RAM or above min required and 40 GB HDD space for vista. Ok..... better try with 1GB RAM.
Thanks
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
I just bought a new Dell running 64-bit Vista Home Premium. My problem is, when trying to install my printer, it says the drivers are not compatible with the 64-bit operationg system. The Dell website has...
Contact the Printers Manf. or go to its web site for drivers.
If that fails, you may want to daul boot with a 32bit system.
Also, you may want to Gogle the printer for a 64bit driver.
Drivers.com, Drivers downloads.com
Aug 27, 2009 | Microsoft Windows Vista Home Premium with...
Missing boot manager
go to system bios (using F10 key on the start "Commanly") then press F9 for restore defaults, and insert the Bootable Vista DVD into the drive, it will solve your prob.. otherwise in bios mode make sure that all the drives (HDD & CD/DVD Rom) are properly installed.
good luck
shafky
Jun 19, 2009 | Tablets & eReaders
Gateway laptop modle mx8711 windows failed to load
Try to start in safe mode and then when it finished loading shut it down again. Boot again it should boot to windows if it not, maybe a corrupted files or some files are missing.
Apr 01, 2009 | Microsoft Windows? Vista Home Premium...
My m2n32-sli premium vista edition motherboard refuses to boot up when i put 6 gbs of memory. How do i solve this issue?
Hi iimarceloii, did you check the FAQ section on Asus web site?
Using Vista 32bit/64bit edition or win XP;
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=M2N32-SLI%20Premium%20VISTA%20Edition&os=24
Basically Asus wants you to use 2GB of memory until windows has been completely installed & completely updated before you can add more memory to the system.
Than you can increase your memory to 6BG. To see all the FAQ's from Asus, click on this link; http://support.asus.com/download/download.aspx?SLanguage=en-us
Type: M2N32-SLI into the search window & click the arrow button.
Good luck iimarceloii!
Merry xMiss
Mike
Dec 21, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Adobe cs3 installation in vista 64bit
I am sure but I think it isn't compatiable with vista home ..
Jun 07, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Microsoft Windows Vista Ultimate Edition Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
