I need to reprogram my autostart model as1855 fm and dont know how. i believe it is a sequence of hood pin switch taps and hitting buttons on remote
SOURCE: COOL START REMOTE NEEDS REPROGRAMMING
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Posted on Dec 23, 2008
  • 37 Answers
SOURCE: remote control settings
There's two options, depending on the brand of remote. The most common is that the reciever located in the fan ceiling canopy has the same switches. Check how they are set and match it on the remote. The other option is that the reciever matches the frequency of whatever the remote is set to. To set this you have to turn off the circuit, wait a minute or so, turn it back on. Then on the remote, hold down the "stop" button for a few seconds. It should be set. I'd check the receiver first though. I should mention also, that when they come from the factory, the switches are usually all in the OFF position (or possibly all in the ON position). Unless they were changed on installation (which may be the case if you have more than one remote controlled fan) they are probably set that way. Try that first.
Posted on Jan 30, 2009
  • 2920 Answers
SOURCE: auto start will not function
you will need to have the remote reprogrammed probably at the dealer
Posted on Feb 03, 2009
redbeard00
  • 957 Answers
SOURCE: Power locks won't work from remote
No you dont have to reprogram the remotes. Please give as much info as you can about the problem. What is working and not working. Is every other function working with the unit. Is this an after market autostart or OEM (from FORD) or is it one of the vehicle security systems?
Posted on May 28, 2009
Mike258
  • 1498 Answers
SOURCE: I have a prestige remote starter-APS99BT3BCF4. It
H there,
That noise you hear under the hood? That means you are close.
Can you locate it?
It is likely the relay that sends power to your starter.
If you have to, start at the solenoid. There is a thin wire (IN YOUR CASE MAYBE TWO) and two thicker wires. You are interested in the thin one(s). one should lead to a relay that looks aftermarket.
This should be the source of the noise you hear.
Comment me back when you find it. Include a description of wires attached to it. and if any look like thery came loose.
Like I said, you are very close
Mike
Posted on Dec 01, 2009
2000 toyota corolla autostart stopped working
place the remote on the start button to depress it,if it start,replace the remote battery.
Jan 28, 2014 | 2000 Toyota Corolla
Bought a 2002 jetta that has a prestige remote start on it. it worked fine a few months. Today nothing works..it won't start, or even trigger the start sequence, and the door lock/unlock won't...
There are two possiblities that could prove to be the fault; hood pin switch and remote start shutdown switch. If the vehicle is equipped with a hood shut down switch, you will need to make an adjustment to it for the remote starter to function. Search around the drivers side edges of the engine compartment for a push pin.If the pin is a stand alone it will be mounted near the headlight inserted into an existing hole. It may also be attached to a bracket. The remote start shutdown switch is a toggle switch located under the drivers side of the dash,usually to the left of the brake pedal, depending on the installation.
If nothing above solves the problem, you may need to reprogram the remote to the unit.
May 23, 2011 | Prestige Remote Start
I have recently purchased an 97 suburban it comes with a remote starter but i hae tried to start it via the remote and nothing happens i know that its soposed to work cause its the ltz model thanks for...
if you know the battery in the remote is good, you may need to reprogram the remote. does your keyless entry work? are they both on the same remote? ive reprogramed a replacement keyless entry for a 97 by using a short jumper wire on the obd II plug. you have to jump two of the pins and then hit the remote button a few times till it locks/unlocks then its synced. off hand i dont remeber which pins but google is your friend. not sure if this will also work on the remote start, if they use the same remote than it should.
Feb 21, 2011 | Chevrolet Suburban Cars & Trucks
I have a 95 yukon and my auto start will make the truck crank over but it wont start. I can push the auto start button on the remote but it will just keep cranking the engine over but wont start up but if...
It sounds like your security bypass isn't programmed or needs to be replaced. Try to reprogram it and then start the vehicle. Shut it down and try to start it a second time, if it doesn't start the second time the bypass needs to be replaced.
Dec 15, 2010 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
Module in Initialization mode
if you have a 4 BUTTON REMOTE CONTROL:
You will need to take the unit out of safety mode, to do this you will
need to ground the hood pin switch wire, then put your foot on the brake,
next hit any button on the remote and the clicking will stop. Then you will
need to take the hood pin switch wire off of ground and take your foot off
of the brake and see if the remote will work with the unit
if you have a 2 BUTTON REMOTE CONTROL:
need to put your foot on the brake, next hit any button on the remote and
the clicking will stop. Then you will need to take your foot off of the
Jan 10, 2010 | Remote Starter with Keyless Entry
make sure the button inside the remote makes contact with the outer plastic, might want to open it an try to press it an see if it works...!
May 28, 2009 | 2000 Ford Ranger SuperCab
Auto start will not function
Feb 03, 2009 | 2005 Pontiac Vibe
I have a skylink 318r keypad with receiver to open my overhead door but dont know code as sellers of the home didn't leave this with - how do you reprogram both transitter and receiver?
keypad is model 318K
receiver is model 318R
factory setting for keypad PIN is 0000 #
there is no master reset code
you must have the current code to reset the PIN
if you hit the correct code on the keypad followed by the # key - you will get three beeps.
to change the PIN: (current PIN needed)
enter current 4 digit PIN then *
enter new 4 digit PIN followed by *
reenter new 4 digit pin and *
if accepted - backlight will flash and will sound one long beep
takes 2 CR2032 button cells for keypad
you could sit in a chair one night and start at 0000# then 0001# etc until you get three beeps
then use above procedure to change to your desired code
good luck
Jan 29, 2009 | Locks & Locksmithing
Dec 16, 2008 | 2-Way Remote Starter
Remote starter
The wire under the hood is for the hood pin switch, this wire when grounded will prevent the remote starter from starting, for trouble shooting I would leave this unhooked and make sure it is not touching any metal, also try to remote start your car with the key in the ignition swich if it remote starts you have a transponder issue if not post me and we can go from there
Jun 30, 2008 | 1998 Honda Accord
Computers & Internet Logo
208 people viewed this question
David Payne
David Payne
