Question about Philips Respironics Auto BiPAP Machine DS750HS
Humidifier is not warming. Indicator light had
Humidifier is not warming. Indicator light had been flashing on and off. Lately not on at all.
    Top Expert:
  • 12,223 Answers
Reset the humidifer, Turn off, wait for 3 minutes, and try again.
If the problem persist, see your owner manual go to the website from the supplier and get support via ONLINE chat for fix it.
God bless you
Posted on Oct 12, 2013
Unit does not turn on
I am having the exact same issue after cleaning the unit, it doesn't start; no light indicator at all. Anyone has a fix or recommendations?
Nov 14, 2013 | Heaven Fresh HF 707 Digital Ultrasonic...
We noticed the humidity went down to 30% and I adjusted the rate to increase Now our Aprilaire 400 says to change the filter. I did that, and it still says to change the filter. The furnace runs fine....
If your humidifier is equipped with a Digital Humidifier Control with Water
Panel change indicator, after replacing the Water Panel, turn the control
knob to the "Test/Reset" position until the "Humidifier On" light blinks to
reset its timer. (Blower must be operating and HVAC calling for heat.) Be sure
to turn the control knob back to it's original setting. If the "Humidifier On"
light continues to blink, your humidifier is in Test mode. DO NOT LEAVE THE
CONTROL IN TEST MODE OR HUMIDIFIER WILL NOT OPERATE.
Jan 27, 2011 | Aprilaire 400 Humidifier
How do I know it is working?
Hello, You can tell if the humidifier is working if you see water flowing into the drain line. Also , when the furnace turns on you should here a click at the solenoid valve on the humidifier, this means that the solenoid is open and letting water into the humidifier.
Jan 22, 2011 | Aprilaire 700 Humidifier
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
Nov 19, 2010 | Sunbeam (0013871361) Humidifier
I replaced the water panel on our aprilaire 600 humidifier. I adjusted the thermostat to call for heat to test it. When the dial (non-digital control panel for the humidifier) is turned to test/reset,...
Thank you for contacting us with regards to your model 600 Humidifier. The Change Water Panel indicator should flash when the control knob is set to the Test/Reset mode. The flashing indicates that the timer has been successfully reset. However, the humidifier should operate for the first 60 seconds of Test mode as long as your furnace is running. If your humidifier does not turn on, contact your installer. The humidifier may require service.
We appreciate the opportunity to be of assistance.
Sincerely,
Brett Phillips
Technical Support
Research Products Corporation
Nov 01, 2010 | Aprilaire 600 Humidifier
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifier does nor work and no water light is on
"Take the humidistat out of the humidifier and look for the 3 slits below the restart button, take a hair dryer and send some warm air into those slits for 5 minutes. That usually recalibrates the humidifier."
May 20, 2010 | Clarion DA-1030 Humidifier
Indicator says " change water panel"
Go to www.aprilaire.com and order the water panel for your type of humidifier . The model # should be located on the humidifier. the box you get from them will have directions on how to change. you will then need to turnyour dial on the humidistat to TEST until the green light BLINKS, this will reset the panel reminder timer.
Jan 20, 2010 | Aprilaire 700 Humidifier
Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Apr 10, 2009 | Honeywell Humidifiers
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Philips Respironics Auto BiPAP Machine DS750HS Logo
182 people viewed this question
Top Philips Respironics Humidifiers Experts
Mack Baxter
Dennis
Are you a Philips Respironics Humidifier Expert? Answer questions, earn points and help others
