Question about Samsung Galaxy Tab Tablet PC
Hi. A day ago, I used my Tab to a very low point; and it had only 3 % battery life when I was using it to send a message, then the phone went hanging. It was in this condition till the battery went out, all the while getting hotter. Now, I tried charging it and putting it on to no avail. What do I do?
    Problem Solver:
  • 19 Answers
When it freezes n this such way you should hold in the power button and after about 30seconds or just over the unit will cut out and reboot. but as you are too late to try this you may have caused it to burn out.
if the device is younger then 2 years send it back to get fixed.
samsung offer a 2 year guarentee with their devices, they may not fix your one you send back but they will replace it with a referbished unit of the same spec.
Posted on Oct 26, 2013
3 Suggested Answers
libandgh
  • 34 Answers
SOURCE: my samsung tab is not
charge wth ur tab charger
dont charge with usb
Posted on May 30, 2011
SOURCE: my samsung galaxy tab 10.1 fell down three days ago & the screen cracked a little. worked fine till yesterday when it went off suddenly and now boots up showing the blue screen with samsung on it.
My samsung galaxy tab 10.1 fell down three days ago & the screen cracked a little. worked fine till yesterday when it went off suddenly and now boots up showing the blue screen with samsung on it. have tried rebooting it severally and running down the battery to recharge to no avail
Posted on Sep 18, 2013
Why does the Battery Drop so fast On Samsung tablets
mostly it depends on your usage, more the usage faster the battery drop.
In general, below are few ways you can reduce your battery drop.
1. keep screen brightness moderate or low
2. User power saver
3. dont keep your tab for charging for longer time, it reduces battery life (eg, you might keep it charging before sleep until morning)
4. Kill all background running apps when not needed
4. check your carrier signal strength, use airplane mode when there is not network
5. keep in sleep mode when you are not using (just hit lock button
Jun 23, 2017 | Samsung Tablets & eReaders
My sound notification for messenger only works some time?. I have someone send a message to check it and maybe two out of five make the noise?
Hi Virginia,
Your iPad tends to stop using internet when you lock it to save battery, instead it periodically checks services like Facebook and Messages to save battery life. You currently cannot turn this off, if the notifications are very infrequent you may want to try re-installing the app to see if this solves your problem.
Sometimes apps have a battery saving setting in the app itself, you may want to open the app to see if this is the case.
I hope this helps,
Niall
Oct 20, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Why did my RCA 10 inch tablet power down and now will not turn back on? It does not show any sign of charging - no battery symbol, no lights, nothing.
battery have residual power which last few minutes to allow safely switch off, as you used this power, it shut down. this residual reserve is usually between 3% to 5% of capacity.
and do not fiddle with it till you recharge it, reset will not work while there is no power, any other "trickery" will not work either.
now, plug battery to known good charger and charge it for 24hrs, do not switch it on during that time nor disconnect from the charger.
after this it should be starting and working normally, if it does not - it is still under warranty and you should return it to the place of purchase for repair or replacement, even if you do not have receipt. tablet have it's serial number and can be traced in the store to day, and even hour and minute when it was sold...
hope this short info will help you - do not forget to vote...
Feb 02, 2015 | Tablets & eReaders
I have had my kindle fire since christmas 2011. i went to go turn it on saturday and it is just dead... the battery was 3/4 full just a few minutes before so i know it wasnt that. i went immediately to go...
Will it charge when connected to your computer then recover your data. Open replace the battery with a fully charged one to see if the charge circuit is at fault. Buy a new one
Apr 03, 2017 | Amazon Kindle Fire
Galaxy tab p1010 not charging
Hi!Maybe this will work:1. Try a different charger.2. Connect it to a pc to see if that can charge your tablet (if this is working, it means that your charger is the problem)3. If none of the above works, then is the battery or the device itself that don't function properly and you should go to check it on a autorized service shop.
Hope this will help you!
Have a nice day!
Sep 28, 2011 | Samsung Galaxy Tab Tablet PC
I am trying to upgrade my firmware from 2.2 to 2.3, i followed the intruction on the internet, then after i run the procedure instead of seeing pass messages after upgrade it shows faild. the problem i...
Good day. I''m afraid you might have accidentally got the Operating System of your Samsung Tab corrupted. Im referring to your firmware. Usually if the firmware upgrade failed you need to retry it until it be successful. If you restart it or discontinue the process it will cause your Samsung Tab to be corrupted resulting into failure of the boot up process. You might need to contact samsung tech support for this or bring your equipment to the nearest center. They might need to check the software install and usually their software specialist will fix it for you. Sorry for what happen with your tab but i know the samsung repair center can fix it for you. Hope this information will be helpful to you. Have a great day.
Jun 15, 2011 | Samsung Galaxy Tab Tablet PC
The Ipad battery: how many hours a day can you use Ipad without the battery acting up after a month. I do not have a computer Ipad is it. the batter seems to be low even after being charged up 100...
The iPad 3 is not yet available, yet thousands of designs for cases and covers have already been made for this new apple product. Decide what colour you want your ipad 3 cases to have, and what design. This is not all! Not at all! Due to the many hot apple iPad 3 accessories available you will also be able to choose the material out of which your accessory will be made. Anything from wood to titanium. Maybe an interesting plastic? Flexible rubber? Or maybe aluminium? What will it be?
Jun 24, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Samsung Galaxy Tab Tablet PC Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
