Question about Konica Minolta Office Equipment & Supplies
Code c-0201 minolta - Konica Minolta Office Equipment & Supplies
My minolta bizhub c6501 has a trouble code of c0203. How do I fix it?
Description
Intermittent C-0201 (C0201), C-0202 (C0202) and C-0203 (C0203)paper lift error codes.
Solution
PROBABLE CAUSES:
1.The trail edge paper guide (p/n A03U R756 00) may not be pressed against the paper. This will allow the paper to fall backwards and induce the error code.
Instruct the end user to check the position of the trail edge paper guide whenever paper is loaded into the paper tray.
2. Coupling for the tray lift for Tray 1, Tray 2 or Tray 3 is obstructed or out of alignment causing the tray to not lift.
Inspect the coupler in the back of the machine for paper preventing the pin from seating in the coupler. Check alignment when tray is inserted. If out of
alignment try to adjust the drive to properly align.
Oct 04, 2017 | Minolta Office Equipment & Supplies
HOW TO PROGRAM STI30-0201 WITH WYSE TERMINAL
Hi
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Jul 02, 2014 | Symbol Sti30-0201 Synapse Adapter
Keep getting a p1320 code
code p1320 refers to ignition signal--circuit malfunction===causes--wiring---ignition coil/ module---ignition system---CKP sensor---ECM IT is the same as flask code 0201
first to check is the crank sensor then the ignition module.
Jan 13, 2014 | 2001 Nissan Maxima
Canon iRC5185i with the erro code E000007-0201 . i need the solution to clear this erro
Manual:
E007-0201 Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
I can't understand what it means.
Oct 25, 2013 | Canon irc5185i
NO CODE FOR LG TV
try these codes:0060 0393 0032 0400 0055 0024 0240 0025 0579 0737 0270 0239 0454 0313 0186 0201 0384 0629 0132 1957 1949 0721 0738 0846
Aug 16, 2010 | Gemini Sound Products SBR3B Remote Control
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
Apr 07, 2010 | Office Equipment & Supplies
Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Feb 08, 2009 | Toshiba Satellite M30X Notebook
Excel formulas
{=max(if(category column = category in query, price data column))}
Nov 18, 2008 | Microsoft Excel for PC
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
