Question about Jandy Laars Lite2 Lg 250,000 Btu Heater
Lasts pool heater lg. No gas valve opening. Checked sty.with guide everything pointed to control board. Bought one installed board, switch, thermometer control and temp sensor. All readings the same 500mg to control board from switch.Nothing coming out. I think wire coming out th to gas valve th is the ground. When I bypass board with wire from switch to th on gas valve it opens and fires up. Any thoughts? Driving me crazy. By the way I got another new board with same results.
  • 128 Answers
Sounds like flame sensor.
Posted on Nov 02, 2013
Testimonial: "Where is the flame sensor located on a laars lg heater"
  • 22 Answers
SOURCE: Jandy lite 2 LG pool heater
ignition control board failure
Posted on Feb 18, 2009
  • 3 Answers
SOURCE: Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Posted on Mar 12, 2009
johnsonr1
  • 91 Answers
SOURCE: Laars LG 250,000 Bypassed Safty's But NO Burner Light
Have you checked your pilot generator voltage while everything is connected properly? You may have a shorted wire or limit or even thermostat. If you jump the TH connections on the gas valve, it would lead to shorted, inoperable safety, thermostat.
If everything is connected properly, the MV reading should be 500+, less than this and you are losing power somewhere.
Posted on Aug 22, 2009
  • 246 Answers
SOURCE: I have a 10 year old Jandy RS4 controller which is
must replace water tem sensor
Posted on Aug 25, 2009
ftw1952
  • 10319 Answers
SOURCE: The control panel on my
Most likely the main circuit board has a faulty relay incorporated on it. You can get top expereince help at this web site if you wish to determine the exact problem you have with these guys. They are good
http://www.poolspaforum.com/forum/index.php?showtopic=10966
Posted on Jun 29, 2011
Error code hf hayward model h200ped2 after replacing control module
HF is a flame sense failure. make sure the off\on switch is in the on position (on gas valve in heater) if you are using an automation system, you should see BO when the pool is running and heat is not called for. if this is the case, you need to take the heater off of remote control and try to manually call for heat using the buttons on the heater. if it fires, that would make me think that there is a compatability issue between the new board on heater and old board on automation.
Jan 21, 2015 | Hayward Pool & Spa
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
Hayward spa pool heater pilot on, heat does not ignite burners
Don't really think the gas company would be checking your pool heater, they most likely just checked their gas connections. I would suspect a few things; control module, thermostat, gas valve, pressure switch. You say you get pilot light, and as long as it doesn't turn off and on, as if it is not being sensed, then I would suggest the control module is fine. If the pilot and main burner is controlled by the same valve, and your pilot light stays lit, then I would suggest the thermostat is fine. I take back the pressure switch since the pilot will ignite. I would check power to the gas valve solenoid and see if the control module is trying to open the gas valve. I would suspect low voltage, probably around 24v. If voltage is present and no gas, I would say you found the problem.
Apr 09, 2013 | Hayward H Series Pool & Spa Heater...
Jandy lite 2 pool heater. The heater is about 5 years old. Pool and hot tub share the same water supply side. Heater started shutting off at lower and lower tempatures over the last few months. Heater...
if you have not been keeping the water balanced, there may be a buildup in the pipes inside the heater core. this would cause the heater to work harder, produce less heat transfer and cause the over temperature sensor to kick out before meeting the set point.
Apr 01, 2017 | Pool & Spa
I have a H250IDL heater. All electrical installation is correct. I have converted it to propane with the proper conversion kit that I have ordered from Hayward. My problem is, the gas valve will not...
Have you checked the flame sensor is in the correct position and it clean , and the connection is tight , also check pressure switch is working, tubes not spilt .
Feb 27, 2017 | Heating & Cooling
Jandy Laars Lite2 Lg 250,000 Btu Heater Logo
60 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
