Question about Microsoft Xbox 360 Controller
Both my controllers have stopped turning on, batterys are good though?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 139 Answers
Try to sync them with your system using the sync button on the top of the controllers and the front of the system.
Posted on Nov 13, 2013
Key won't turn the ignition 2000 s-series saturn
Test the battery if it does absolutely nothing when trying to turn over, if battery is good, check for a bad fuse possibly, check leads from ignition control module to the starter, possibly could be a bad ignition switch in the car. if the car attempts to turnover but wont start, you could be looking at a bad starter, fuel pump. Before you go too far into it though, just get the battery tested better to start small with these things, Good Luck!
Dec 04, 2016 | Saturn Cars & Trucks
My brake lights are staying on even when I unplug the brake light switch
The brake light switch is an input to the BCM - body control module , do you know about BCM'S - electronic module ?
Stop Lamps
When the driver presses the brake pedal, the switch contacts open and battery positive voltage is interrupted to the BCM. The BCM then supplies voltage to both the turn/stop lamp supply voltage circuit and trailer rear turn/stop lamp supply voltage circuits. The BCM also supplies voltage to the CHMSL though a dedicated circuit.
could have DTC'S stored in the BCM
DTC B3445 00: Stop Lamp Circuit
Circuit/System Description
The stop lamp switch is used to sense the action of the driver application of the brake pedal. The body control module (BCM) provides a low reference signal and a B+ reference voltage to the stop lamp switch. When the stop lamp switch contacts close indicating the brakes have been applied, the BCM will apply battery voltage to stop lamp relay control circuit and the center high mounted stop lamp (CHMSL). When the stop lamp relay receives battery voltage from the BCM, the relay coil is energized and the stop lamp relay switch contacts close applying battery voltage to the STOP LAMPS fuse to illuminate the left and right stop lamps.
DTC C0277 00: Brake Pedal Position Sensor Calibration Not Learned
DTC C0297 00: Brake Applied Output Circuit
DTC C0890 00: Device Voltage Reference Output 3 Circuit Voltage Out of Range
In the event that DTC C0277, C0297, or C0890 sets as current in the body control module (BCM) is an indication of a possible internal BCM malfunction or programming error. There are no external circuits available to diagnose on this vehicle with respect to these DTCs.
Your best bet would be to take your vehicle to a qualified repair shop or the Cadillac dealer.
Jul 17, 2016 | 2008 Cadillac Escalade
RC-261 fails to turn on/off Insignia TV. Remote stopped working (batteries good)
Check the battery contacts inside its battery compartment for any rust or dust accumulated. Clean them well. If this too do not help you, check the remote control for its infrared emission. In some cases, cleaning the remote control may be necessary. If you wish to get more details about how to check, repair and clean a remote control, visit this site. Pull up older posts. One among the post has details.
Mar 24, 2013 | Insignia RC-261
Both my humax 9150t recorders remote controls stopped working at the same time on each machine. also the machine controls have stopped working
We are all having the same problem. It must be data error sent for TV listings. No idea what to do though. Just wait I guess. Very annoying though.
Dec 14, 2011 | Humax Televison & Video
I have Intermatic E1020C timer and it wont stop ticking
Timers like this are powered by a battery or ac power, the battery one is easy "yank it out", as for ac powered that's a bit harder and if you don't feel comfortable working with live electric stop here...
Now if your still with me, if it's ac it is powered from somewhere, if you can find a breaker that controls it that would be good. Shut off the breaker, disconnect the wires from the timer motor wire nut them then tape the wire nuts and turn the breaker back on, Your done...
Now if you cant find the breaker it's a lot harder, you will have to cut the wires "HOT" this means good high voltage cutters and one wire at a time, please don't touch the end of the wires or the metal part of the wire cutters. It can be done if your careful.
Same end result though, once cut wire nut and tape each wire before going on.
Good luck...
Tim
Mar 24, 2009 | Heavy Duty Intermatic Wall Switch Timer...
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Microsoft Xbox 360 Controller Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
