Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Where is the fuel pump fuse located 1999 gmc jimmy
    Novelist:
  • 95 Answers
Underhood fuse block- "ECM B" 20 amp fuse. It supplies voltage to the fuel pump relay in the same fuse block, which sends voltage down the line to the fuel pump when the engine computer turns the relay on.
Posted on Oct 19, 2013
Fuel pump
the fuel pump is supplied power via the fuel pump relay. The relay gets power for the fuel pump through the ECM B fuse. This fuse also supplies power to the vehicle control module.
Apr 05, 2013 | 1999 GMC Jimmy
99 jimmie fuel pump let go replaced and now wont give gas to start . fuse ok for pump relay seems ok run on eather . new pump is good bench checked
Relay seems ok ??
Do you have power and ground at the fuel pump plug where it goes into the gas tank ?
Feb 04, 2013 | 1999 GMC Jimmy
Trying to find the fuse position in the fuse box for the fuel pump for a 1993 gmc jimmy. do not have the cover for the fuse box.
Here is a link to your fuse panel. The fuel pump is controlled by the ECM through the fuel pump relay which is located on the firewall by the brake booster.
http://ww2.justanswer.com/uploads/ZZdaryl/2009-12-20_014123_fuse.gif
Thank you for using fixya, and good luck
Apr 19, 2010 | 1993 GMC Jimmy
Where is the fuel filter fuse located on a 94 jimmy
fuel filter has no fuse. Do you mean fuel pump or fuel pump relay fuse?
Feb 21, 2010 | 1994 GMC Jimmy
1999 GMC Jimmy acts like it wants to cut out as if there's no gas
fuel pump relay or fuel pump on it's way out....I assume you changed the fuel filter and that didn't help?
Feb 19, 2010 | 1999 GMC Jimmy
Is there a breaker or a fuse for the fuel pump and if so where do I locate it?
the fuel pump has a fuse, it is located in the under hood power distribution box, it just beside the fuel pump relay, believe it is marked ECM 1.
Sep 12, 2009 | 1996 GMC Jimmy
Where is the fuel pump relay for a 1991 gmc jimmy?
  • COMPONENT LOCATIONS RESULTS
Relay - Fuel Pump 1991 GMC Truck S15 Jimmy 2WD 4.3L TBI 6cyl The Relay - Fuel Pump Under hood, driver side, upper firewall, mounted in relay block
Jul 02, 2009 | 1991 GMC S-15 Jimmy
Fuel pump blowing fuses
replace the fuel pump relay, it is burned closed from the shorted fuel pump.
Apr 13, 2009 | 1993 GMC Jimmy
Does a gmc jimmy have a fuel pump reset button?
yes it does and it is located in the fuel tank. BIG job to repair/replace
Feb 15, 2009 | 1999 GMC Jimmy
My 1999 gmc jimmy was just siting and running and just shut off and will not statt back up it jst keeps trunibng over
It could be the fuel pump. Turn the key on and listen for a whirling noise in the fuel tank. Check fuses and fuel pump relay, if they are ok, replace fuel pump.
Jan 03, 2009 | 1999 GMC Jimmy
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
75 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
