Question about Whirlpool Dryers
I have a Whirlpool Ultimate Care II Dryer that started giving me problems. It started with a funny smell (kind of like the burnt varnish smell others talked about). Then it stopped working (timer still running, but drum not turning). I opened it up and cleaned it out (there was a lot of lint) and it worked again for a little bit, but then stopped again. I was pretty certain that it was the motor (it seemed like the source of the smell) so I put in a new one. I also put in a new belt and rollers and updated the idler pulley. it seems to be running smoothly, but i still smell that smell. What should I do next? I'm starting to feel like I'm throwing money into a pit.
  • 1 more comment
  • tim plain
    tim plain Oct 12, 2013
    Just wanted to add that it's a gas dryer. Any suggestions would be greatly appreciated.
  • tim plain
    tim plain Oct 27, 2013
    UPDATE: I feel like the source of the current smell is the new rollers. I think the original bad smell came from the burnt out motor. I put the old rollers back in and I will say that the dryer is now running more smoothly, so perhaps the new rollers weren't the right ones. Still have a bit of odor. Any ideas about getting rid of the odor?
  • tim plain
    tim plain Nov 06, 2013
    UPDATE: The source of the smell was the new rollers/new belt. I took off both and put back the old ones and the stink is much better. Not sure if I just got bad parts. For those that might think that it was the belt and couldn't be the rollers...I put the rollers in a ziplock bag and today I opened that bag and holy hell did it stink. How this info is useful to someone.
  • Official Brand Answer
  • 408 Answers
Hello Tim Plain. My name is Melanie and I am a representative of Whirlpool. We apologize about the frustration you have experienced with your dryer. If you would like us to look into this further, please provide your name, the name of the site you were contacted on (Fixyha.com), your user ID name (tim plain), your phone number, your address, the full model and serial number, and ticket number (61373) to Whirlpool.Digital@whirlpool.com. We would be happy to review your concerns further. Sincerely, Melanie
Posted on Oct 14, 2013
    New Friend:
  • 34 Answers
Have you checked for singed wiring. That stink you described, has a way of lingering. If your unit has a removable panel, you may be able to use your own nose to help pinpoint the source of it, if something is still trying to burn out. Electronic components also have the "stink" when they fry. If it were me, and that thing dies again, I don't think I would attempt to resuscitate it again. I've found some really good, servicable dryers on "Craigslist". Best of luck!
Posted on Oct 12, 2013
Testimonial: "Thanks for your response. I also had the thought that it might be an electronic component. All signs pointed to the motor, so I felt it was a pretty good gamble. I actually did a smell test before replacing the motor--Made an attempt to run it and then opened it up and stuck my nose in there and the stink really seemed to be coming from the motor. Also, as you said the stink can linger and that may be the case. I'm feeling like it may be getting better and the problem may have been the old motor. The first load I did had a bit of the stink, but the second load seemed better. I'm going to run it a few times on air only and see if that helps clear the out the stink. If the problem continues...I'll go back to craigslist for another one. This one only cost me 150 bucks and we've gotten seven years of service out of it."
  • TheQuartermiler660 Oct 12, 2013
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
erpaalai
  • 999 Answers
SOURCE: Whirlpool Ultimate Care II Dryer timer knob
The timer cam is not aligning the internal switches. Replacing it is the only fix.
Eric
Posted on Sep 18, 2009
  • 249 Answers
SOURCE: Fisher & Paykel ED56 Dryer Motor Problem.
sounds like the motor is burned or the wiring!
Posted on Jan 01, 2010
hunter19_46m
  • 7482 Answers
SOURCE: The dryer rattles while running. I've cleaned out
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My whirlpool ultimate care II electric dryer won't
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Jul 21, 2011 | Whirlpool Dryers
    The smell of my laundry
    Try putting one more sheet in the dryer as far as the Tide with Downey it`s propbably getting rinsed out when your washer goes through the rinse cycle.
    Feb 20, 2010 | Whirlpool Dryers
    Whirlpool ultimate care ii dryer, only works when continuosly pressed the start button. What can be the problem. whirlpool ultimate care ii dryer model gew9878lw0
    More likely than not either the start/run switch on your motor wen't bad, or the motor windings itself. Either way you need to replace the motor #279827 around $100 on up.
    Not tough to get to if you know how to gain access to the cabinet, just remember that the blower wheel and motor threads going into the blower wheel are LEFT hand thread,
    have fun, and best of luck,
    ttfn
    Feb 04, 2010 | Whirlpool Dryers
    Burning smell
    Stop using the dryer! You are probably close to having a fire if you continue to use it. The whole vent system should be taken apart, cleaned, the heat limit sensors checked and the duct cleaned. Your dryer is overheating and is a danger.
    Aug 11, 2009 | Dryers
    Musty Smell
    spray motor and gear housing surrounding with insecticide, roaches may be nesting there that gives out the foul odor
    May 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II washer went dead during fill cycle
    Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
    May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Slow agitating
    Sounds like a failure in the gear case but the burning smell makes me wonder if you have a problem with the motor. You will need a appliance tech to verify
    Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Dryers Logo
    140 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
