COMCTL32.dll error Toshiba laptop won't start
  • 3 Answers
Maybe retry your signal or turn it on or off again?
Posted on Oct 13, 2013
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Cant sign on to computer
    • 1 Download the missing comctl32.dll file. Locate a website that offers the comctl32.dll file. You can also use the link in the Resources section.
    • 2 Unzip the download file if it is a .zip-type file. Right-click on the file and choose "extract" to make the file available in a .dll format.
    • 3 Install the missing comctl32.dll file in the proper folder on the computer. If the operating system is 64-bit Windows, copy comctl32.dll to the "C:\Windows\SysWOW64" folder. If the operating system is 32-bit Windows, copy comctl32.dll to the "C:\Windows\System32" folder.
    • 4 Restart the computer by clicking on the "Start" button and selecting the "Restart Computer" option.
    • 5 Open the computer program that previously displayed the error message stating that the file comctl32.dll was missing. This will verify the program now works properly.
Nov 21, 2011 | Dell Latitude D 600/610
I have toshiba satellite 2065cds, when started windows loads, then when logon/password screen show, error occurs, "missing msvcrt.dll.. how can i reload the msvcrt.dll file into windows without...
does your laptop have a cd drive and do u have a computer with a burner i can find you the msvcrt.dll and can walk you thru how to copy it into the right directory.
Mar 15, 2011 | Toshiba Satellite 2065CDS (PAS206U-S6CW8)...
Faced with following message/s: Winlogon.Exe Could Not Locate Component. This Application Has Failed To Start Because Comctl32.Dll Was Not Found. User Interface Failure. The logon user interface DLL...
Without an original OS installation disk, you are probably at an impasse as far as trying to repair the problem yourself. You might try this option to see if you might be able to get into the computer.
Try this first:
You can try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message "Please select the operating system to start" or hear the single beep, immediately press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
Failing this, you will probably have to send / take the computer to a repair facility to get the machine back online. I fix this kind of issue on a regular basis.
Jan 23, 2010 | Acer Aspire 5000 Notebook
I'm using Dragon Ver 10.1 and dictating inside microsoft word 2007. I"m running XP Pro with SP3. My computer keeps freezing ONLY when Dragon is running. Sometimes I load Dragon and before I even begin to...
hai friend this is the problem of your configuration try increasing your virtual memory size or you have to increase your ram capacity and this Installs and runs on Microsoft Vista 64-bit systems only
Jul 28, 2009 | Computers & Internet
C:\Users\toshiba\AppData\Roaming\fyxegtbu.dll
You have Malware or Spyware. If you can load your destop, download and run http://malwarebytes.org and http://www.spybot.com. If you can't load your desktop, download (including updates) from another computer and run on your desktop. Good luck.
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
Fairly old toshiba laptop with hal.dll error wont even boot now..
Well it must be an error when you install the windows XP...If you choose just to upgrade the your system then it might have an error on dll. Please reprogram your system i mean reformat your system. And not just upgrading well if ever you have an important data in the system then you must have a externat storage device then take it on your laptop.
Mar 08, 2009 | Toshiba Computers & Internet
PowerCinema for Toshiba error message
Here we go, just paste this site in your browser and download the dll. This should correct your problem:
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
http://www.driverskit.com/dll/msvcr71.dll/2373.html
Mar 07, 2009 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
