Question about Harman Kardon AVR 70
Problem with Harman Kardon AVR-70II Turning on
Problem with Harman Kardon AVR-70II Turning on all by itself- I looked this up and (1) solution is listed below. My reciever resets,but it turns on when I input into LD or CD or VCR1... so, is my stand by power relay bad or whatd need to do? I unpugged all lines for 1hour,no solving this. *SOLUTION Owners Manual, Pg 18, TV Auto Function. "If a video feed is connected to the TV VIDEO IN jack during the installation, that signal is used to trigger system turn on. Even when the receiver is turned off, the presence of a signal at the TV VIDEO jack will automatically cause the receiver to turn on. As long as the signal is present, the receiver will remain on. When the TV or other source is turned off, the receiver will automatically return to a standby mode within 5 minutes." Try using another video input.
    Top Expert:
  • 12,223 Answers
You must open the receiver in order to Test the relais for dirty contacts or faulty. Try to clean the contacts with contacts cleaner, or see any loose wires around and resolder the wires from coil
God bless you
Posted on Oct 12, 2013
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Followup on higlider's problem. Now it has to be turned on ten times before it stays on. Email from Harman Kardon only suggests taking it to an authorized repair shop. It is clear that it is not from speaker short or overheating, because it only happens when the rcvr is cold.
-higlider
Posted on Jan 05, 2008
SOURCE: goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Posted on May 31, 2009
  • 308 Answers
SOURCE: AVR amber light will not return to blue after
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Posted on Mar 04, 2010
SOURCE: Harman Kardon AVR325 stays in standby mode
Was a solution ever found for this? I have almost the same problem, except that mine makes a horrible sound through the speakers before it shuts off. However, after an attempt or two, mine usually starts working and sounds fine (I love how this thing sounds!). It seems to happen more when I've let it sit for a week or two. When I use it regularly, it usually works fine. It's almost like it knows when I'm about to give in and replace it... because it will start working again! Maybe I just need to make an effort to use it more....
Posted on Jun 11, 2010
SOURCE: My Harman/Kardon AVR 140 is stuck on stand by mode
Try unplug the power. Wait a few minutes. Reconnect the power.
Posted on Jul 25, 2010
Harman kardon remote codes
https://www.google.com/#q=+Harman+Kardon+AVR+70 This is where I found it.
Nov 27, 2014 | Harman Kardon AVR 70
Harman Kardon AVR7550 turns itself off.
check to see if there is a reset switch inside on transformer bd. could be dirty. clean with contact cleaner.
Nov 26, 2011 | Harman Kardon Audio Players & Recorders
I have a harman kardon avr-8000 that has no audio, only clicking noise in speakers when turning up and down.Any ideas?
i have a hk avr8000 5.1 it is doing the same thing i replaced the preamp circuit board bit i still have no audio
Dec 19, 2010 | Harman Kardon AVR 8000 Receiver
Harman kardon avr 100 no power
check the fuses it help the power !
Jun 07, 2010 | Harman Kardon AVR 100
Harman kardon avr 7200.1 no volume left front speater
could be a few different things. if you have tried another speaker that you know is in working condition then it might be a connection on the amp itself or the terminal could be bad. does it look coroded or is there anything obstructing its connectivity?
Feb 18, 2009 | Harman Kardon AVR 7200 Receiver
Hook-up
http://wzpo.ask.com/r?t=p&d=cap&s=fwpus&c=a&l=zr&o=sb&sv=0a300516&ip=29b28a2c&id=9C081BFE154A69ACB38D55982924AB2E&q=manual+of+harman+kardon+avr+120&p=1&qs=121&ac=29&g=33c8zcdlUuHiRw&en=te&io=0&ep=&eo=&b=alg&bc=&br=&tp=d&ec=10&pt=Harman%20Kardon%20AVR%20120%20Receiver%20Owner's%20Manual&ex=tsrc%3Dtxtx&url=&u=http://www.manualnguide.com/download/manual-guide/harman-kardon-avr-120-receiver-owners-manual.html. have a look in manual above from page 9.
Sep 06, 2008 | Harman Kardon AVR 120 Receiver
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Dec 05, 2007 | Harman Kardon AVR 120 Receiver
Receiver turning off by itself
I'm having the same problem with my AVR 435. Did anyone ever figure out how to fix this?
May 10, 2007 | Harman Kardon AVR 435 Receiver
137 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
