Question about ASUS Computers & Internet
Why is the green led blinking on my M3N72-D motherboard
    New Friend:
  • 3 Answers
The flickering green LED on the motherboard is illuminated by the standby power supply, a small completely independent, always on, 5 volt power supply labeled 5VSB usually, output is on the violet wire.
Here's some more detailed instructions about how to check a PSU.
Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
Posted on Oct 12, 2013
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Blinking led
Download the manual from the manufacturers website.it will have what those lights mean when they flash. Have you tried to update the bios recently?
Nov 06, 2013 | Fujitsu Siemens FSC Server-Mainboard...
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
Ibm x3400 is not powering on green led blinking continiously
Hello here is others with the same problem:
http://www.ibm.com/developerworks/forums/thread.jspa?threadID=397434&start=15&tstart=0
It looks like the power button is failing.
The fault could also be the mainboard.
Try also to talk with a autorished dealer or a repair shop.
Good luck
Dec 15, 2012 | IBM x3400 Server
Compal RM CY25 Laptop. new battery won't charge.
Unfortunately, the charger socket in the motherboard does not drive electricity to the battery to get re-charge it. It is a typically motherboard problem(Do not confused with a power jack problem). I can not be repaired it.
Two options work always hook with power adapter or get ride of her.
Jan 30, 2010 | Computers & Internet
New motherboard only green light on motherboard turns on nothing
check your power connector, wire that runs from the case to the motherboard. let me know how you went with that cheers
Mar 06, 2009 | Intel Motherboard
Green light blink and off
Hun, I really hate to be the bugger here, but its probably time to get a new comp. This computer is out of date by a long shot (as I can't even find the motherboard's user manual online.) I suspect that if there is a light blinking, it is blinking to the same as it's beep codes. So my suggestion is following this (as many key boards either have a small speaker for beep codes or they have an led for the same thing.) http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph07107&dlc=en
Aug 31, 2008 | HP (P2074-69003) Motherboard
No power and blinking green LED
It may not be that the bios needs clearing, take the left side panel off and look for the 'JBAT1' terminal on the mobo and put jumper cap from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. start the pc then set the time and date when prompted ans save settings.
Feb 09, 2007 | ASUS K8N Motherboard
Computers & Internet Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
