Question about Toto Carlyle 1-piece Elongated Bowl Toilet
I need to replace a toto toilet seat however it is the one with the rubber grommets ,but one of the grommets has failed and I can not tighten or loosen the bolt, If I can get the bolt out it is obvious i will have to replace the grommet but i can"t get the bolt or the grommet out. Any suggestions how to get the bolt and grommet out ? I have tried everything i know without damaging the toilet.
3 Suggested Answers
  • 17 Answers
SOURCE: I have a Toto toilet and am trying to replace the
hi there
this type of seat has rubber gromits that squeeze up when you tighten the screw.if it wont tighten up the gromit may have failed and would need to be replaced.
good luck
Posted on Dec 18, 2010
  • 3074 Answers
SOURCE: My Toto toilet does not
this site may help, Tim:
http://www.guillens.com/Toto/1P_Toilet/Prominence_MS894114.htm
Posted on Jan 10, 2011
Testimonial: "Perfect suggestion!! The picture chart at this website made it easy to find my unidentified part!"
Toto toilet seat slides to side
you have to tighten these from the bottom of the bowl...use open end wrench or cresent to do
Oct 28, 2012 | Toto Round Maple SoftClose Toilet Seat...
I have a Toto toilet and am trying to replace the old seat. BUT the bottom is a solid piece and makes it impossible to access the seat bolt for tightening. I began loosening the seat bolts. now I have a...
hi there
good luck
Dec 18, 2010 | Toto Carrollton Toilet Tank - ST774S-01 -...
Need to replace toilet seat but cant get at bottom of bolts to tighten nuts as it is enclosed
Use deep sockets and not a wrench. Place flat head screwdriver on the top screw for resistance, while tightening or loosening the bolt at bottom with the deep socket and wrench.
Oct 10, 2010 | Toto Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 | Home
I have a Toto saftclose toilet seat but it doesnt close softly!!!
If it is something you can adjust, there will be an area on the hing. There also may be a small cover over the adjustment screw.
Apr 01, 2009 | Toto Round Maple SoftClose Toilet Seat...
How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Dec 22, 2008 | Toto Aquia II Dual Flush Toilet
Toto Carlyle 1-piece Elongated Bowl Toilet Logo
63 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
