Question about Compaq PS110 Computer Speakers
Power adapter output supply - Compaq PS110 Computer Speakers
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
What voltage power supply do need for the momo force feedback wheel i go one second hand and it was missing the power supply please could help?
Hi, Here all the specs of the Power adapter you looking for. Thanks and have a nice day ! J -
- Adapter model: ADP-18LB C
- Adapter Input: 200-240 V / 50-60 Hz ~ 400 mA
-Adapter output: 24.0 V - 0.75 A Output Plug - Outside Diameter (mm): 5.50
- Output Plug - Inside Diameter (mm) : 2.10
-Output Plug - Barrel Lenght (mm) : 12.00
- Output Plug - Polarity : Center positive.
thanks and have a nice day J -
Mar 30, 2010 | Logitech Momo Force Racing Wheel PC
I have ACER Aspire One Model KAV60. Need to Identify Power supply
There are three adapter manufacturers, the Acer One runs on 30 watts and 19 volts. Below are the specs for the adapters.
10001081
DELTA
30W Adapter DELTA 30W 19V 1.7x5.5x11 Black ADP-30JH BA
LF
60003544
LITE-ON OPT
30W Adapter LITE-ON 30W 1.7x5.5x11 Black PA-1300-04AC LF
60002015
HIPRO
30W Adapter HIPRO 30W 19V 1.7x5.5x11 Black HP-A0301R3
Jan 24, 2010 | Acer Aspire One PC Notebook
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Problem in my adapter
From what you said I gather that your AC/DC power supply (power brick) is not working (Suppling voltage to the router). Well this is a case of getting a new power supply. What you can do is find out the voltage output and the current output in amps of the Brick. This information is located in writing on the power brick. Take this information to your local electronics store and get a power brick that has the same voltage, polarity, and current rating as the old power brick.
Aug 31, 2007 | Lucent ORiNOCO AP-1000
Compaq PS110 Computer Speakers Logo
26 people viewed this question
Top Compaq Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Compaq Audio Player and Recorder Expert? Answer questions, earn points and help others
