Question about Sewing Machines
Baby lock blqc - stretch fabric pulls down into throat plate. Is there an alternate feedplate? Thanks!
    New Friend:
  • 3 Answers
Hi, make sure you use needles for stretch fabric. If it still is not helping, cut paper towel in strips and put it under your material and then stitch. The paper tears away very easily afterwords.
Posted on Oct 12, 2013
kent581
  • 87 Answers
SOURCE: needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Posted on Mar 24, 2009
sew dutch
  • 25 Answers
SOURCE: Kenmore Sewing machine model 385.1884180, feed dog quit pulling
Sometimes there is a lot of lint build-up in the feed dog, it may want to move, but it can't because of the dust. Remove dust before you oil!
Posted on Jun 23, 2009
SOURCE: sewing with double knits
pull about 2 inches of thread from the needle and bobbin and hold them tightly toward the back of the machine when you start to stitch. continue holding them until the fabric is stitched beyond the edge of the presser plate and the hole is no longer visible.
Posted on Dec 23, 2011
SOURCE: My 6440 Viking keeps knotting up on the underside..it will take a few stitches ..lock up..and when I remove the fabric the upper thread is all tangled up in the throat plate..can you help me..I have t
try changing the needle
rethread the machine top & make sure to use every thread
guide
& make sure the bobbin is inserted correctly into the bobbin
case
clean under the needle plate & in the bobbin area for lint or
threads
make sure the top thread hasn't come off the thread take up
lever
Posted on Aug 15, 2012
  • 1564 Answers
SOURCE: My Pfaff Classic Style Quilt 2027 is getting large thread snarls on the underside of the fabric.
Top tension problems. Tighten the tension.. and make sure you hold the threads when starting a seam.
Posted on Sep 03, 2012
I need a manual for the very first baby lock quilters' sewing machine, BLQC. Does anyone know where I can find it?
https://www.ebay.com/itm/Baby-Lock-Quilters-Choice-BLQC-Instruction-and-Reference-Guide/113017110828?hash=item1a5058412c:g:EdoAAOSwb39bCLBa
Feb 26, 2018 | Baby Lock Sewing Machines
My Baby Lock A line Series sewing machine just started bogging down real bad?
how is it boggin down? have you tried a new needle-one for the fabric being sewed
make sure the power cord is plugged in snuggly
clean under the needle plate and in the bobbin area for lint or loose threads
Apr 30, 2016 | Baby Lock Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
Feb 26, 2015 | Baby Lock Imagine
I dont know.if I am doing it.wrong my thread keeps snapping from the needle my ? Is there a certain way to place the bottom bobbin? For a brother xl5130 sewing machine
If your bobbin was in wrong you would get the "crows nest" on the underside of the fabric. There can be several thing that can cause this: your tension is to tight, for normal sewing is usually around 3-5 (check your manual for proper setting). Your needle or throat plate can have a bur on it that is snagging the thread causing it to break. Needles should be thrown away after 50 hours of sewing to avoid problems. The needle can have a slight bend (from over use) and is rubbing on the throat plate causing it to break. and finally...your just not holding your mouth right! :) (...and sometimes this is really true!). Check your tension, pull the thread, change your needle, rub your finger over the throat plate be sure all is baby skin smooth, re thread you machine...deep breath, relax and start again. Hope this helps, Happy sewing.
Nov 30, 2014 | Sewing Machines
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
Fabric does not move need to be pulled by hand
first of all NEVER pull the fabric... you'll only break the needle, damage the throat plate and maybe even break something below the throat plate.
Check your feed dogs... it may have been set to darn or embroider.... look for a switch near the sewing area.
Feb 25, 2013 | Sewing Machines
Threads stuck under needle plate
take a tiny screw driver & gently unscrew the screws in the needle plate ,, make sure not to damage the screws & clean out the thread & any lint in that area & also the bobbin area
because if the screws are the slightest bit damaged then when you sew & the fabric moves over them the burrs on the screws will pull the threads in the fabric & can damage the fabric
Mar 06, 2012 | Baby Lock Evolve
I am trying to shir using elastic thread in my bobbin but my fabric will not shir & my elastic there jams causing me to start all over. I have studied many tutorials. It seems I need to tighten the...
Have you wound the bobbin with the shiring under tension? you need the shirring elastic to be stretched somewhat as it goes onto the bobbin so that when stitched out, it relaxes and pulls the fabric up.
And yes, usually you need to tighten up the bobbin tension also to stretch the elastic some more.
The Ellure has a horizonal drop in bobbin so you will need to access this to adjust the tension. This may require unscrewing the two screws holding down the needle plate (metal flat plate you sew over). Take this off and now you'll see the bobbin holder area clearly. Look where the tension spring is, the little groove you pull the thread into when threading up. Is there a small dial just near this, about 7mm across? it will have a groove in the top and hopefully a + and - marking.
IMPORTANT: carefully make a note of where it is set now. Take a picture or write a little diagram down so you can get it back to normal setting. Use your little accessory screwdriver and carefully turn it one click to +, then test sew. YOu may need to turn it up 3 clicks to get the elastic stretched enough. Just make sure you know where to set the dial back to when you are done.
Also, remember you won't be able to shir heavy fabric, just light weight cottons work best.
I find that stitching lots of straight lines of shirring like you see tube bodice sundresses made in ready to wear is very hard, factories will have a machine that sews 20 rows at once. And getting enough gathers is trial and error with a domestic sewing machine.
Here's how I do it. Turn down top selvage edge of the fabric width you want to gather, turn down about 10mm and straight stitch around. Now on the wrong side with a sewing marker pen rule lines down from here across the fabric width spaced 1 cm apart. Now lie shirring elastic on these lines and stitch over it with a narrow zig zag stitch making sure not to catch the elastic with the needle. Start each sitching seam one cm from the raw edge of the fabric and finish the seam the same way.
Now I pull the elastic up from each side pulling all of them evenly until I"ve got it gathered enough. Now place right sides together and stitch the fabric into a tube catching the elastic ends in and securing them.
I hope this helps you out.
Jul 19, 2011 | Baby Lock Ellure
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
