Question about LG Washing Machines
Water entering machine will not stay comes back out drain line
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Drain valve not closing properly
Posted on Nov 06, 2013
4 Suggested Answers
  • 51 Answers
SOURCE: flood error
Disconnect from electrical supply. Get someone strong to tilt machine to get fluid out off bottom tray.Mop & dry floor....try now
Posted on Jul 24, 2007
  • 298 Answers
SOURCE: water would not come into washer. cleaned filters
it could be in your hose
Posted on Dec 17, 2010
  • 15 Answers
SOURCE: i have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
Posted on Apr 20, 2012
I have a xt500c thermostat the display goes blank stay off a few days the thermostat comes back on and the unit will run than it will go off again
Sounds like you have a clogged drain. Drain is draining enough to clear the float switch, unit comes on produces water, water backs up and trips the float switch again therefore killing power to the tstat. Shop vac the drain line!
Jun 30, 2017 | Heating & Cooling
Bent flexable water pipe no water coming out need to replace
need more information --make and model --is this a drain line and water not pumping out or inlet line and water not entering you can resubmit or edit your request
Sep 24, 2016 | Washing Machines
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
Water is entering the machine but going out the drain pipe immediately
Drain pipe too low there I usually a mark line on back of washer
Dec 13, 2014 | Washing Machines
F20 error code
copied from the net..............
The "F20" fault code is indicating NO WATER IS BEING DETECTED ENTERING THE WASHER OR THE PRESSURE SWITCH IS NOT TRIPPING OR SENSING A TRIP.
If there is no water in the unit:
Make sure that both valves at the water source(s) are turned on all the way and water enters.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit:
Verify drain pump operation.
Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
Verify there is not a siphon problem.
Press STOP twice to clear the display. The machine will drain for 3 minutes before unlocking the door.
Unplug washer or disconnect power.
Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU).
Check all hoses for possible leaks.
Plug in washer or reconnect power
Verify pressure switch operation.
I recommend calling a service technician to diagnose and repair your washer if water will entering the machine and not siphon out.
cheers
Aug 03, 2017 | Kenmore HE2 Plus Front Load Washer
Machine keeps icing up and switching off
When you say ices up do you mean the line ices up back to the compressor. is water overflowing over sump tray? or is it dumping out drain? If you are not getting water over the evaporator plate then it will frost up the evaporator plat all the way back to the compressor.if the water is dumping into the drain during freeze cycle check the dump valve this will not let sump tray stay full of water. make sure water filter is good as this will not let sump tray stay full fast enough. is water pump pumping water over the evap plate?
Jan 03, 2014 | Kitchen Appliances - Others
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full load...you can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Sep 09, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Im my washing machine the problem , the water coming in
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no missing or broken blades on the impeller and that the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 02, 2009 | Washing Machines
Not getting clothes clean
Check your drain hose for siphoning. this is a common problem, make sure only about 8 inches is sticking into the drain, and the drain line is higher then the mid point of the washer, ex: drain hose must not leave the washer and head directly to the floor, must make a loop upwards, then enter a drain appx. 3+ft high. Drain hose from washer not to enter drain plumbing more then 8".
Jun 25, 2009 | Kenmore Elite 45986 Front Load Washer
Front Loader Wont Purge Water and enter Spin Cycle
it is the drain pump, it is nt working due to lack of power entering its supply line or there is something stuck in the impeller,or its winding failed, u can check it by observing or wait till machine reach the drain cycle when you hear a humming sound during the drain cycle, you isolated already the supply to the drain pump it means the drain pump is working but there is something blocking the hose,impeller and or the pump motor is weak already. if so, call an authorized servicer or service fr the company to do the job, or if u want to fix it by yourslf, first lay down the hose of the machine at floor level, water will comes out, drain it,with that it means no problem with the water line from the tub of the machine to the drain hose, remove the back cover from there u can see the pump get a mechanical plier to remove the clamp,slide the pump or unscrew it if is installed that way then u can check now the pump physically, sometimes small pins is blocking the impeller if there is nothing and when you touch pump is so hot-it is electrically defective-the winding is weak or just what i have said earlier it is blocked or mechanically defective -replace the pump assy- u can order it -try www. repair clinic .com
Apr 06, 2008 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
