Question about Whynter ARC-143MX 14,000 BTU Portable Air Conditioner w/ 3 Fan Speeds, AC, Fan and Dehumidification Modes, Remote Control, 24-Hour On/Off Timer, 384 m3/h Airflow, 1250 Watts, Washable Pre-Filter & 3M Antimicrobial Filter
Replace the fan in a Whynter 14,000 BTU Portable Air Conditioner with Dehumidifer and Remote Model # ARC-14S
2 Suggested Answers
  • 1156 Answers
SOURCE: Whynter Portable Air Conditioner Model:
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Posted on Aug 18, 2011
Control panel lights on whynter 12000 btu portable air conditioner .can't read some numbers
This is due to the detrioting condition of the display, sometimes an even lite press with fingers on the display may help. This happens due to loss of contacts inside due to poor quality of display or aging.
Oct 13, 2015 | Whynter ARC-12S ECO-FRIENDLY 12000 BTU...
Fuse keeps blowing on my Whynter portable ac
Is your compressors motor capacitor replaceable? I know that on a split system, a dead capacitor (typically a 35uF) can cause increased current draw, to the point of blowing fuses, though I've never had to replace one on a portable unit. I usually replace them with a 30uF capacitor, roughly the size of a "200ml can of softdrink".
Apr 11, 2014 | Whynter ARC-14S ECO-FRIENDLY 14000 BTU...
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Loose Parts
Fan Blades
Mounting Brackets
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
Whynter ARC-143MX 14,000 BTU Portable Air Conditioner w/ 3 Fan Speeds, AC, Fan and Dehumidification Modes, Remote Control, 24-Hour On/Off Timer, 384 m3/h Airflow, 1250 Watts, Washable Pre-Filter & 3M Antimicrobial Filter Logo
Top Whynter Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Whynter Heating and Cooling Expert? Answer questions, earn points and help others
