Question about Saws
Sawzall 6509-21 stopped running jerks when switch is depressed but will not run new switch and brushes
4 Suggested Answers
  • 553 Answers
SOURCE: My 0719-20 a56a sawzall motor runs well. The blade
I'm afraid this is one that needs to go to the manufacture. You can contact them at this link:
http://www.milwaukeetool.com/
Posted on Jun 13, 2010
rowdy45176
  • 2176 Answers
SOURCE: The Sawzall runs but has
either worn brushes or an armature problem, I would unplug the tool and look at the brushes first and check the brush spring for collapsing, then rotate the shaft by hand and look into the brush tube for the commutator condition. If it has unusual wear patterns or discoloration then it is probably bad and needs replaced.
Posted on Jun 06, 2011
  • 304 Answers
SOURCE: Milwaukee Sawzall Plus just stopped running
Remove the handle and check there is power going to the switch, if not unplug and remove and repair/replace .the cable.
If there is check the brushes are long enough and are not stuck in the brush holders. Other wise take it to a repair agant.
Posted on Jun 05, 2012
Does 6509-31 sawzall have thermal overloads
No the 6509 does not have a thermal overload.
Start by checking the brushes & brush springs then test the switch & cord
It is possible you burnt the armature out but brushes, switch, or cord is more likely.
Mar 07, 2015 | MILWAUKEE ELECTRIC TOOL CORP Milwaukee...
May 29, 2012 | Saws
The Sawzall runs but has lost power. The brushes are producing a large amount of sparks. The tools motor sounds like it's not coming up to full speed. Got any ideas of what may be causing this?
Jun 06, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
My 18 volt stealth sawzall just started to run slow as if the battery was about to die... would that be the brushes... its the second one I have that problem with
yes, brushes are worn, or more specifically, the springs holding the brushes are. You probably got a set of spares in the box, if not, you can get them as many are standard sized.
Oct 19, 2010 | Garden
Runs for 5 to 10 seconds at full power after that it barely runs milwaukee sawzall 6538-21
you might want to check, this tool possibly has a 5 year warranty. if not do you see any excessive sparking at the brushes? this could indicate an open on the armature or a stuck brush. Let me know and I will do what I can
Aug 26, 2010 | Milwaukee Tool Saws
Changing the switch of the folding handle 18 v. Sawzall
try going to Milwaukeetool.com and under service you can download a wiring diagram for the tool, usually they show the routing.
Mar 19, 2010 | Milwaukee 2690-24 18-Volt Hammer-Drill,...
Super Sawzall 6527 just stopped working. I did an
could be a couple things, unplug tool and look at the pins on both the cord and the pin housing to make sure none pushed back, next remove handle half and remote electronic and look for a loose flag terminal at the brush holder, look for loose wires on the switch, (give a gentle tug) and remove the brushes and look for unusual wear patterns and possibly a burnt brush spring. Let me know if you need more help.
Nov 22, 2009 | Milwaukee Tool Saws
No power to saw works sometimes then stops and wont run
check the cord for the pins pulling out and then I would test thru to the brush holders. Also if you are comfortable removing the handle half check for a loose connection to the switch and the flag terminals at the brush tubes. Let me know if you need more help.
Oct 23, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Saws Logo
37 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
