Question about KitchenAid Dishwashers
Kitchen aid dish waher kude60hxss washing and no water coming out of sray arms
  • eddy
    eddy Oct 16, 2013
    new engineering dish washing system , control board problem
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
heatman101
  • 43501 Answers
SOURCE: bosch dishwasher no water coming from arms but not blocked
Here is a tip that I wrote about that....
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Apr 21, 2010
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
I have a kitchen aid dishwasher that is not dispursing the water enough to clean. I have cleaned the entire unit with commercial cleaners and have added vinegar to the washer without dishes. And still it...
You need to remove the wash arms by turning the nut in the centre of the arm and remove,then unblock the holes that are in the arms and replace them,test if the arms now turn and you can see a differance then also check there is salt in the salt dispensor located at the bottom of the machine.
Dec 30, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Model D03000XL-0 Serial FB2202753 Water runs, arms work but the dishes just don't get clean. How ols is this unit?
to wash dishes you need 140 deg water tempt / fresh dergt . rinse aid /like jet dry / dyr form is good . and clean screens in bottom . / wash arms holes must be clean . and water level in tank up to heating element . all of these help to do a good job . low water tempt and hard water art the two most common problems found .. mm feed back pls ..
Dec 07, 2009 | Washing Machines
My Kitchen Aid KUDI01FLBL3 is not cleaning my
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Sep 16, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen aid NOT CLEANSING DISHES
It sounds like you are not getting enough water to make the dishwasher function effectively. Could be a bad valve could even be that the spray arms aren't letting through enough water.
Jan 01, 2009 | Dishwashers
I have a Kitchen Aid Superba KUDS24SEBS1. The inlet water pressure is good and the dishwasher fills and starts the wash cycle, however, after the initial spray of water, it seems that all of the water...
when "full" of water, the normal height of level is about 1/2 below the heater assy(large blackish grey coil below he spray arm).. if theres enough water in the unit nad its still not "spraying",its quite possible that your filter/chopper assy is clogged and cant let water through. try removing hte spray arm and under that you will see 5 torx15 screrw holding down top filter plate under there to the left youll see another t15 screw covering hte chopper assy area. claen out sump of debris this may be your issue
Nov 26, 2008 | Dishwashers
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
