Question about Asko WL6532XXL Washer
My asko wl6532 xxl isleaking from the bottom of the washer
Tub isleaking water maytag front loader model#mhwe200xw00 font door water lleaks
Sorry but with internal leaking it is virtually impossible for anybody on this FixYa forum to guess remotely what is wrong with your washer- apart from the fact that it appears to need a new front door seal.
You really need to call in a service engineer.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 14, 2011 | Maytag MAH8700A Front Load Washer
Asko W6021 Front Load Washer error detected "F3 Outlet Blocked". How to solve this problem?
The drain access is at the bottom left of the washer. Insert a screw driver in the right side of the cut-out and and gently pry open. Open the drain pump. You will need a small container and a towel to help catch the water that will be coming out. After letting all the water out, clean out any objects in the drain pump. After cleaning out drain pump, put everything back together and restart washer.
Feb 05, 2011 | Asko W6021 Front Load Washer
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
ASKO washer WL6511XXLPP
Purchased ASKO Washer WL6511XXLP and Gas Dryer with pedestals, 12/01/09. It threw a drum paddle during 2nd. wash cycle. Damaged several articles of clothing.
ASKO replaced the paddle 2/19/09 after a lot of phone calls (lip service from the ASKO 800 #). They claimed the part had to come from Sweden (reason for delay).
Washer threw another drum paddle during 4th. wash cycle. Damaged several more articles of clothing. We have made no claim for the damaged clothing, the retailer has been cooperative.
ASKO has promised to replace the washer after the retailer we purchased the washer from, strongly encouraged them to do so. We are still without a washer (03/23/09). My wife and I are retired, I am 76. Point being; we do not abuse washing machines and we don't like going to a launder-mat.
I know this is not the venue to address this problem, but am at my wits end.
Mar 22, 2009 | Asko WL6511W Front Load Washer
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Mar 21, 2008 | Asko W640
Asko WL6532XXL Washer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
