Question about Eureka Vacuums
Eureka bravo model#9206 need owners manual - Eureka Vacuums
  • Eureka Master
  • 18,391 Answers
reddevil6
  • 1673 Answers
SOURCE: eureka canister vacuum model 6865- cleaning
70227 is the part number for the owner manual, but you would have to have it order it. You can call 1-800-282-2886, this is Eureka's customer service, they don't have it in their data base, but maybe they can find something for you.
Posted on Mar 11, 2008
  • 77 Answers
SOURCE: help
the handle should be down and the top may have a tab on both sides to pry out with screwdriver. lay handle down and turn machine over. look closely around base between cover and there should be a tab to push on and cover comes off.
Posted on Jun 12, 2008
  • 10865 Answers
SOURCE: Need user/owners manual for Eureka Whirlwind Big Cup model 4686
hello chris. here is the link to use to get your downloadable manual
http://www.eureka.com/owners_guide.jsp
Posted on Jun 19, 2009
VacuumRepair
  • 438 Answers
SOURCE: eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Posted on Apr 07, 2010
  • 377 Answers
SOURCE: I have a eureka bravo
Check out this URL:
http://www.svcvacuum.com/beltrep2.html
looks like it has just what you are looking for. Would appreciate a thumbs up on this if you find it beneficial. Paul
Posted on Oct 04, 2010
What type of belt does the Eureka Uno take?
Here is a link to the belts for the Eureka Uno models and a manual you can view which has instructions.
Eureka Uno Belts and Manual
Dec 15, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
Replace the belt on a Eureka contour model 2900 upright vaccum. I just want to see a picture of the way it comes apart. It a almost new and just needs the belt replaced.
I have listed below a link to the owners manual for your model and a link where you can purchase the belt you need. Hope it helps you!
Eureka Contour 2900 Owner's Guide
Eureka Contour 2900 Belt
Oct 26, 2009 | Vacuums
Jun 19, 2009 | Vacuums
Eureka Bravo II poor suction at hose
check if the hose is clogged or the fan is broken
Jan 04, 2009 | Eureka 7606 Bagged Upright Vacuum
Download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Sep 15, 2008 | Eureka Boss Superbroom Bagless VacuumStick...
Vacuums Logo
110 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
