Question about Lasko 2534 40", Executive Tall Blower Tower Fan & Ionizer With Remote Control
The fan works and so does everything else on it when I press the power button on the tower itself, but the remote control doesn't work when I press the power button on it. I placed new alkaline batteries in it, but still doesn't work. The remote control is dead.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Cant fix a remote control yourself. That is what factory service is for.
they will either give you a new remote control ,if you are still in warranty, or quote you a price on a new replacement remote control.
Replacement remotes usually run $40.00 to$ 80.00 for vcr's
video cassette recorders , but should be considerable cheaper
for fans.
use make,model and serial number to find factory service website. You can download a new owners manual.
can find factory service website by typing in
"factory service for[ make] of fan & model #
in the search box of google.com or bing.com
or ask.com or yahoo.com
Posted on Oct 13, 2013
2 Suggested Answers
SOURCE: remote control fan
Most probable you have the same problem as I . Only mine does not turn on the light anylonger. I removed the controller from the fan assy and found the circuit board had fried for what ever reason. There is no replacement board available. So you will either have to wire in a new switch for the fan only, or replace it.
Posted on Dec 31, 2007
Kichler ferron 60" why ceiling fan will only move very slowly remote does not appear to be working
If your Kichler ceiling fan appears to have lost touch with the remote, try the usual routine of removing batteries from the remote, pressing all buttons to eliminate a stuck button as the cause, then reinstalling the old batteries (or new batteries) and testing operation. If no luck, disconnect power at the source, not the fan, pause briefly (to "reset" the fan control) and reconnect power to test operation. If still no luck, the remote receiver in the fan or the remote itself may be defective.
Aug 31, 2014 | Kichler Dryers
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
Remote control doesn't work
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
Aug 29, 2012 | LG 37LD450 37 in. TV
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Region Codes
1. Disconnect your player from its power source for thirty seconds
2. Reconnect your player to its power source
3. Press the Power On button on your remote control
4. Press the Enter button on your remote control
5. Press the 8 button on your remote control
6. Press the 4 button on your remote control
7. Press the 2 button on your remote control
8. Press the 6 button on your remote control
9. Press the 9 button on your remote control
10. Press the Enter button on your remote control
11. Your player should now place itself in Standby mode
12. Press the Power On button on your remote control
It should also work for HT-Z310T and HT-510T and its variantes...
Apr 12, 2008 | Samsung HT-Z310T Theater System
Lasko 2534 40", Executive Tall Blower Tower Fan & Ionizer With Remote Control Logo
552 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
