Question about Lasko 2534 40", Executive Tall Blower Tower Fan & Ionizer With Remote Control
I can't get my remote control to work. I have a Lasko elite wind tower ionizer with remote control model 2534. I put new batteries in, but to no avail. They are alkaline energizer.
    Scholar:
    New Friend:
  • 102 Answers
You have posted under sewing machines so may not be seen by the experts here.
Posted on Oct 12, 2013
SOURCE: lasko tower fan with ionizer
Try a can of compressed air. It's impossible to get inside.
Posted on Jul 22, 2008
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
  • 3 Answers
SOURCE: Lasko 2554 Wind Tower Fan
I have a Lasko HVB, but this might apply to your fan:
Without taking the thing totally apart, here's an idea you can try: The power cord on some models (like mine) has a "warning" tag. I had the damn thing all apart when I noticed this. (Well, who reads 'em??) Seems like there's a mini-fuse in the PLUG itself that, when it blows, there's nothing you can do about it except send it for repair to a factory authorized yadda yadda yadda. Who's going to do that??
If you plug in and NOTHING HAPPENS, here's what might turn out to be an cheap and easy fix: cut off a few inches of the plug end of the cord and go buy another plug at Ace. Heavy duty might be appropriate: don't think I'd want a lamp plug on this baby. Get one that's easy to install. Bring the cut off piece and they'll help you find exactly what you want.
If you want to open it up, there's a screw behind the Lasko medallion, remove that and you can snap out the grille. You can see where the cord comes in from the back of the blower housing. Test the line voltage. If you're not getting about 120VAC, it's the plug.
If that's not it, IMHO, without some knowledge or a schematic, you're screwed. That'd be me. It wasn't the plug.
-Chuck
Posted on Sep 22, 2008
SOURCE: lasko ionizer tower fan works but does not blow
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I had a similar fan which quit. I could sometimes get it to start spinning by banging on it. Finally took it apart. Lots of small screws, all small phillips. As I suspected, the "thrust bearing," which supports the rotating components, had become "stiff." I thought that it would be a non-friction (ball bearing), but it is only a bushing, with washers supporting the shaft. With the motor opened up, I greased the bearing with petroleum jelly, and reassembled everything. It is spinning very quietly now. Final comment - this is probably more work than the average fix-it person would want to take on, but it is doable. It took about two hours, start to finish. I could do it in less than one hour now that I know how to do it.
Posted on Aug 30, 2009
  • 15 Answers
SOURCE: Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Posted on Nov 09, 2009
The fan works and so does everything else on it when I press the power button on the tower itself, but the remote control doesn't work when I press the power button on it. I placed new alkaline batteries...
cant fix a remote control yourself. That is what factory service is for.
they will either give you a new remote control ,if you are still in warranty, or quote you a price on a new replacement remote control.
Replacement remotes usually run $40.00 to$ 80.00 for vcr's
video cassette recorders , but should be considerable cheaper
for fans.
use make,model and serial number to find factory service website. You can download a new owners manual.
can find factory service website by typing in
"factory service for[ make] of fan & model #
in the search box of google.com or bing.com
or ask.com or yahoo.com
Oct 11, 2013 | Lasko 2534 40", Executive Tall Blower...
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
My lasko mod 2554 fan powers up but the fan will not work. The fan oscilates and the ionizer and timer lights all work.
It is possible that the main capacitor is faulty and so the coils is not enerrgised to start.
So check winding and check the capacitor for open.
Test capacitor by charging both the pins to mains voltage and shorting the pins to see if charge is retained.If retained the capacitor is good, if not replace.
Sep 08, 2010 | Lasko 2554 Wind Curve Tower Fan with Fresh...
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
My Lasko 42" Wind Curve fan when I plug it don't power up. Pluged at diferents outlets, same results Thank you
Check out the cord, (frayed or broken) usually right where it enters the unit, and the switch.... if these check out then the motor has gone bad...
heatman101
Aug 18, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How does the "Ionizer" work on the Lasko 48" Wind Curve Tower Fan ? Shouldn't there be a HEPA filter to change or something to clean once in a while ??
I'm not exactly sure, but I think that an IONIZER has nothing more than metal blades inside that 'capture' dust/debris and contaminants from the air on the blades. There should be a handle to lift up on and remove the long blades.
You rinse the blades with warm soapy water, dry them and put them back in. Maybe I'm thinking of something else, but to me, that is what an ionizer is. Hope this helps at least some.
Best, Jennifer
Jul 08, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
How do you clean the ionizer in a lasko wind curve
You have to take the fan apart. They didn't design it with the convenience of the customer who likes to keep things clean in mind, so you have to get out a bunch of screwdrivers and stuff and roll around on the ground and fight with it until you get it apart. I posted a lengthy post on how to get this model apart, as I just did mine yesterday. Just look for my name on the Lasko models like this one. But be careful and don't try it if you don't think you can pull it off without getting hurt.
Jun 11, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Fan stopped moving
ck thermo / if it quit when running / if thermo is ok / ck the power cord and connections to fan motor / . these units use a one time saftey fuse and if the fail its because the blower is not able to draw proper amperage . due to blockage . ect . / r in some case's a very long or poor cord .. hope this helped mm
Jan 15, 2010 | Lasko 2534 40", Executive Tall Blower...
I have lasko fan sudenly it stoped oscillating can u help me with this ? Lasko 48" Xtra Air Tower Fan with Air Ionizer.Model 4820
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Jul 17, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
My Lasko 40" Tower fan stopped working.
ok everybody who has this model #2534 it seems that the motor has gone bad so you have two choices you eighter find the recipt where you brought it from but there a catch 1 year from the day you brought it from. second choice buy a new motor. third choice buy a new one. sorry!
May 13, 2009 | Lasko 2534 40", Executive Tall Blower...
Lasko 2534 40", Executive Tall Blower Tower Fan & Ionizer With Remote Control Logo
805 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
